Bug Report Hi, a few problems with ps4 streaming with capture card
jakehunter1128
my setup: cpu: i7 6700K ram: 16g (no gpu)
i am using avermedia extremecap u3 cv710 game capture card to stream ps4.,
I got a few problems with obs.
whenever i try to add a video capture device (avermedia extremecap u3) via obs, it onlyshows black screen. i also tried to mess up with settings like custom resolution and other stuffs, it's still black screen no matter what i tried whatsoever.
I also tried to capture using the game capture which turned out to be black screen, too. The only way that makes me be able to get video from "Recentral" (a program that my game capture card uses) is using windows capture in obs. I was able to get a full screen in my obs if i full screened the recentral at the same time. Unfortunately, i just ran into a problem that really came from nowhere and i could not get it fixed, so i m calling help.
Problem: It worked almost perfectly with windows capture and i was able to stream ps4 games yesterday. Today, when i use windows capture to capture ps4, I got a frozen screen when i hit that preview button. I am still getting videos from ps4 with "Recentral", it just doesnt display properly in obs. I am certain that i didnt change any settings in obs. What makes me mad is that it works perfectly yesterday, and i m getting a frozen screen no matter what i try.
Here's the screenshot
e01dnmz1r
log file:
01:23:14: CLR host plugin strings not found, dynamically loading 4 strings
01:23:14: CLRHost::Initialize() attempting to load and start the .NET runtime (null)
01:23:14: CLRHost::Initialize() Found version v2.0.50727 .NET runtime
01:23:14: CLRHost::Initialize() Found version v4.0.30319 .NET runtime
01:23:14: CLRHost::Initialize() attempting to use v4.0.30319 .NET runtime
01:23:14: CLRHost::LoadInteropLibrary() load the assembly plugins\CLRHostPlugin\CLRHost.Interop.dll
01:23:14: CLRHost::LoadPlugins() attempting to load the plugin assembly CLRBrowserSourcePlugin
01:23:14: CLRHost:: Could not find/load browser settings at location C:\Users\Jake\AppData\Roaming\OBS\pluginData\browser.json
01:23:14: CLRHost:: Exception: System.IO.FileNotFoundException: Could not find file 'C:\Users\Jake\AppData\Roaming\OBS\pluginData\browser.json'.
01:23:14: File name: 'C:\Users\Jake\AppData\Roaming\OBS\pluginData\browser.json'
01:23:14: at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
01:23:14: at System.IO.FileStream.Init(String path, FileMode mode, FileAccess access, Int32 rights, Boolean useRights, FileShare share, Int32 bufferSize, FileOptions options, SECURITY_ATTRIBUTES secAttrs, String msgPath, Boolean bFromProxy, Boolean useLongPath, Boolean checkHost)
01:23:14: at System.IO.FileStream..ctor(String path, FileMode mode, FileAccess access, FileShare share)
01:23:14: at CLRBrowserSourcePlugin.Shared.BrowserSettings.Reload()
01:23:14: CLRHost::LoadPlugins() successfully added CLR plugin [Type: CLRBrowserSourcePlugin.CLRBrowserSourcePlugin, Name: CLR Browser Source Plugin]
01:23:15: Open Broadcaster Software v0.657b - 32bit (´・ω・`)
01:23:15: -------------------------------
01:23:15: CPU Name: Intel(R) Core(TM) i7-6700K CPU @ 4.00GHz
01:23:15: CPU Speed: 4008MHz
01:23:15: Physical Memory: 4095MB Total, 4095MB Free
01:23:15: stepping id: 3, model 94, family 6, type 0, extmodel 2, extfamily 0, HTT 1, logical cores 8, total cores 4
01:23:15: monitor 1: pos={0, 0}, size={1920, 1080}
01:23:15: Windows Version: 10.0 Build 10586 (revision 0)
01:23:15: Aero is Enabled
01:23:15: OBS Modules:
01:23:15: Base Address Module
01:23:15: 009F0000 OBS.exe
01:23:15: 60AA0000 OBSApi.dll
01:23:15: 608B0000 CLRHostPlugin.dll
01:23:15: 5E8D0000 DShowPlugin.dll
01:23:15: 60450000 GraphicsCapture.dll
01:23:15: 5E8A0000 NoiseGate.dll
01:23:15: 6D860000 PSVPlugin.dll
01:23:15: 5E880000 scenesw.dll
01:23:15: ------------------------------------------
01:23:15: Adapter 1
01:23:15: Video Adapter: Intel(R) HD Graphics 530
01:23:15: Video Adapter Dedicated Video Memory: 134217728
01:23:15: Video Adapter Shared System Memory: 4160684032
01:23:15: Video Adapter Output 1: pos={0, 0}, size={1920, 1080}, attached=true
01:23:15: =====Stream Start: 2016-04-18, 01:23:15===============================================
01:23:15: Multithreaded optimizations: On
01:23:15: Base resolution: 1920x1080
01:23:15: Output resolution: 1280x720
01:23:15: Loading up D3D10 on Intel(R) HD Graphics 530 (Adapter 1)...
01:23:15: Audio Format: 48000 Hz
01:23:15: Audio Channels: 2 Ch
01:23:15: Playback device Default
01:23:15: Using desktop audio input: Headphones (2- High Definition Audio Device)
01:23:15: Global Audio time adjust: 0
01:23:15: Using auxilary audio input: Microphone (Yeti Stereo Microphone)
01:23:15: Mic time offset: 0
01:23:15: Audio Encoding: AAC
01:23:15: bitrate: 128
01:23:15: Using Window Capture
01:23:15: Scene buffering time set to 700
01:23:15: Video Encoding: x264
01:23:15: fps: 30
01:23:15: width: 1280, height: 720
01:23:15: preset: veryfast
01:23:15: profile: high
01:23:15: keyint: 250
01:23:15: CBR: yes
01:23:15: CFR: yes
01:23:15: max bitrate: 2200
01:23:15: buffer size: 2200
01:40:16: Using Window Capture
01:51:19: Total frames encoded: 50484, total frames duplicated: 33 (0.07%)
01:51:19: Total frames rendered: 50510, number of late frames: 0 (0.00%) (it's okay for some frames to be late)
01:51:19:
01:51:19: Profiler time results:
01:51:19:
01:51:19: ==============================================================
01:51:19: video thread frame - [100%] [avg time: 0.845 ms] [children: 56.8%] [unaccounted: 43.2%]
01:51:19: | scene->Preprocess - [49.6%] [avg time: 0.419 ms]
01:51:19: | GPU download and conversion - [7.22%] [avg time: 0.061 ms] [children: 5.56%] [unaccounted: 1.66%]
01:51:19: | | flush - [2.96%] [avg time: 0.025 ms]
01:51:19: | | CopyResource - [2.25%] [avg time: 0.019 ms]
01:51:19: | | conversion to 4:2:0 - [0.355%] [avg time: 0.003 ms]
01:51:19: Convert444Threads - [100%] [avg time: 0.965 ms] [children: 99%] [unaccounted: 1.04%]
01:51:19: | Convert444toNV12 - [99%] [avg time: 0.955 ms]
01:51:19: encoder thread frame - [100%] [avg time: 1.048 ms] [children: 0.286%] [unaccounted: 99.7%]
01:51:19: | sending stuff out - [0.286%] [avg time: 0.003 ms]
01:51:19:
01:51:19:
01:51:19: Profiler CPU results:
01:51:19:
01:51:19: video thread frame - [cpu time: avg 0.252 ms, total 12750 ms] [avg calls per frame: 1]
01:51:19: | scene->Preprocess - [cpu time: avg 0.024 ms, total 1250 ms] [avg calls per frame: 1]
01:51:19: | GPU download and conversion - [cpu time: avg 0.024 ms, total 1250 ms] [avg calls per frame: 1]
01:51:19: | | flush - [cpu time: avg 0.009 ms, total 500 ms] [avg calls per frame: 1]
01:51:19: | | CopyResource - [cpu time: avg 0.01 ms, total 515.625 ms] [avg calls per frame: 1]
01:51:19: | | conversion to 4:2:0 - [cpu time: avg 0 ms, total 46.875 ms] [avg calls per frame: 1]
01:51:19: Convert444Threads - [cpu time: avg 0.826 ms, total 83468.8 ms] [avg calls per frame: 2]
01:51:19: | Convert444toNV12 - [cpu time: avg 0.821 ms, total 82984.4 ms] [avg calls per frame: 2]
01:51:19: encoder thread frame - [cpu time: avg 0.804 ms, total 40609.4 ms] [avg calls per frame: 1]
01:51:19: | sending stuff out - [cpu time: avg 0.001 ms, total 62.5 ms] [avg calls per frame: 1]
01:51:19:
01:51:19: =====Stream End: 2016-04-18, 01:51:19=================================================
01:51:21: CLR host plugin instance deleted; removing dynamically loaded localization strings
01:51:21: Terminating 0x10e4
Last game capture log:
2016-04-18, 00:58:17: we're booting up:
00:58:17: CaptureThread: attached to process RECentral.exe
00:58:17: D3D9 Present
00:58:17: DXGI Present
00:58:17: DirectDraw capture: Windows 8 not supported yet
00:58:17: (half life scientist) everything.. seems to be in order
jakehunter1128
i just thought about HDCP which might be the thing that caused this, but windows capture should work which it didn't.
R1CH
You're supposed to add the capture card as a video device, not screen cap their capture software. Find out what's stopping you from doing that.
