Hello everyone. I am new to OBS and streaming in general and I've been having problems while streaming. I have a great computer and great internet as well but I can't seem to find a set of stable settings that doesn't make my stream be extremely choppy. I'm not sure where to even start so I figured I'd ask here. For the record I'm streaming fast paced FPS games (Mainly Call of Duty 4, Black Ops 2, and CS:GO)
My Specs
i7 3770k (Overclocked to 4.6ghz watercooled)
16gb Ram
2 GTX 670s (Overclocked to infinity and beyond lol) in SLI
I have verizon Fios.
Speedtest shows 100mpbs down, 70mpbs up
On Encoding I have CBR turned off
Quality balance at 6
Max Bitrate at 3500
Video:
Base resolution 1080p
Resolution Downscale 720p
Filter Bilinear
FPS: 30
Aero Disabled
Advanced: Use Multithreaded Enabled
Process Priority Normal
X264 Preset is fast
Use CFR is checked.
Everything else is stock.
When I stream it looks like this (Example is CoD4 using Game Capture, top right corner is my itunes using window capture)
Any help would be appreciated
My game runs fine. Lower a few settings slightly to keep CoD4 at 250FPS cause I'm so used to playing it that way, same with Blops 2 running at 125. I can keep them stable as if I'm not streaming. But my stream just chugs along. Someone please help?
My Specs
16gb Ram
Max Bitrate at 3500
Video:
Filter Bilinear
FPS: 30
Aero Disabled
X264 Preset is fast
Use CFR is checked.
