http://www.twitch.tv/fhrosty/b/417115968
that is my current quailty
My log:
14:20:54: Open Broadcaster Software v0.522b - 64bit ( ^ω^)
14:20:54: -------------------------------
14:20:54: CPU Name: Intel(R) Core(TM) i5-2410M CPU @ 2.30GHz
14:20:54: CPU Speed: 2294MHz
14:20:54: Physical Memory: 6051MB Total, 3766MB Free
14:20:54: stepping id: 7, model 10, family 6, type 0, extmodel 1, extfamily 0, HTT 1, logical cores 4, total cores 2
14:20:54: monitor 1: pos={0, 0}, size={1366, 768}
14:20:54: Windows Version: 6.1 Build 7601 S
14:20:54: Aero is Disabled
14:20:54: OBS Modules:
14:20:54: Base Address Module
14:20:54: 000000003F2D0000 OBS.exe
14:20:54: 00000000E8440000 OBSApi.dll
14:20:54: 00000000F71E0000 DShowPlugin.dll
14:20:54: 00000000EC970000 GraphicsCapture.dll
14:20:54: 00000000F72D0000 NoiseGate.dll
14:20:54: ------------------------------------------
14:20:54: Adapter 1
14:20:54: Video Adapter: Intel(R) HD Graphics Family
14:20:54: Video Adapter Dedicated Video Memory: 67108864
14:20:54: Video Adapter Shared System Memory: 1711276032
14:20:54: =====Stream Start: 2013-06-12, 14:20:54===============================================
14:20:54: Multithreaded optimizations: On
14:20:54: Base resolution: 1280x720
14:20:54: Output resolution: 1280x720
14:20:54: Loading up D3D10...
14:20:54: Playback device Default
14:20:54: Using desktop audio input: Speakers (ASTRO Gaming USB MixAmp)
14:20:54: Using auxilary audio input: Microphone (ASTRO Gaming USB MixAmp)
14:20:54: Audio Encoding: AAC
14:20:54: bitrate: 192
Warning -- DShowPlugin: Could not create device filter
14:20:54: Using directshow input
14:20:54: Video Encoding: x264
14:20:54: fps: 30
14:20:54: width: 1280, height: 720
14:20:54: preset: superfast
14:20:54: CBR: no
14:20:54: CFR: no
14:20:54: max bitrate: 2000
14:20:54: buffer size: 2000
14:20:54: quality: 6
14:20:56: Total frames rendered: 71, number of frames that lagged: 0 (0.00%) (it's okay for some frames to lag)
14:20:56: =====Stream End: 2013-06-12, 14:20:56=================================================
14:20:58:
