crabbymonkey92
When I'm streaming Planetside 2 to twitch I get some stuttering on the feed about every 10 sec when I watch it live on my PC but not my recorded videos. I tried doing all sorts of things and it would get better but never fixed it even does it when i steam at minimum settings. I don't know if this is normal or what. my current settings are:
Quality: 10
Max Bitrate (kb/s): 3200
Buffer size (kb/s): 5000
Codec: AAC, Bitrate 128
Server: US Central: Dallas, TX
Base Resolution 1920x1080
Resolution Downscale: 1280x720
FPS: 30
Use Multithereded Optemizations enabled
x264 CPU Preset: Veryfast
The rest of the settings I never touched and I do not use a capture card.
I have a good PC and Internet:
Case: Corsair Obsidian 650D
CPU: i7 3930k
Motherboard: Gigabyte X79S-UP5
RAM: Corsair Vengeance 32GB (4x8GB) DDR3 1600 MHz
Power Supply: Corsair AX850 PSU************
Graphics Cards: 2-Way SLI Gigabyte GTX 680 OC
CPU Cooler: Corsair H100
Optical Drives: Pioneer DVR-219L and Pioneer BDR-207DBK Blu-Ray*****************
Boot Drive: Crucial M3* 256GB* SSD
Programs/Games Drive: Western Digital Caviar Black 1TB
Storage Drive: Seagate Barracuda 2TB
Mouse: Razer Naga
Keyboard: Razer Blackwidow Ultimate
Lighting: BitFenix Alchemy Aqua Blue 20cm x2
I'm not dropping any frames when i stream but it still jumps and I dont know why. If someone could tell me what the problem or could recommend some new settings that would be great. I would love to optimize my steam at 720 @ 30 FPS.
In case you need it here is my log:
Quality: 10
FPS: 30
CPU: i7 3930k
Mouse: Razer Naga
Open Broadcaster Software v0.47a - 32bit (´・ω・`)
CPU Name: Intel(R) Core(TM) i7-3930K CPU @ 3.20GHz
CPU Speed: 3200MHz
Physical Memory: 4095MB Total, 4095MB Free
stepping id: 7, model 13, family 6, type 0, extmodel 1, extfamily 0, HTT 1, logical cores 12, total cores 6
Aero is Enabled
Adapter 1
Video Adapter: NVIDIA GeForce GTX 680
Video Adapter Dedicated Video Memory: 2062221312
Video Adapter Shared System Memory: 2147479552
Base resolution: 1920x1080
Output resolution: 1920x1080
Loading up D3D10...
Playback device Default
Using desktop audio input: Speakers (Realtek High Definition Audio)
Using auxilary audio input: Microphone (3- AT2020 USB )
Audio Encoding: AAC
bitrate: 128
Using Monitor Capture
Video Encoding: x264
fps: 30
width: 1920, height: 1080
preset: veryfast
CBR: no
CFR: no
max bitrate: 1000
buffer size: 1000
quality: 8
timestamps for 'Microphone (3- AT2020 USB )' just decided to go wacky. reverting to desktop time. PRAISE WONDERFUL DEVICE DRIVERS
New Scene
Using graphics capture
SharedTexCapture hooked
Total frames rendered: 12813, number of frames that lagged: 9831 (76.73%) (it's okay for some frames to lag)
Output resolution: 1280x720
Loading up D3D10...
Audio Encoding: AAC
bitrate: 128
fps: 30
width: 1280, height: 720
preset: fast
CBR: no
CFR: no
max bitrate: 3000
buffer size: 1000
quality: 10
Server selection: rtmp://live-3c.justin.tv/app
bufferTime: 1469, outputRateWindowTime: 1000, dropThreshold: 1969
New Scene
Total frames rendered: 3996, number of frames that lagged: 732 (18.32%) (it's okay for some frames to lag)
Loading up D3D10...
Audio Encoding: AAC
bitrate: 128
fps: 30
preset: fast
CBR: no
CFR: no
max bitrate: 3000
buffer size: 1200
quality: 10
timestamps for 'Microphone (3- AT2020 USB )' just decided to go wacky. reverting to desktop time. PRAISE WONDERFUL DEVICE DRIVERS [b] I LOLed when i read this way to go Devs[/b]
Total frames rendered: 76, number of frames that lagged: 76 (100.00%) (it's okay for some frames to lag)
Loading up D3D10...
Audio Encoding: AAC
bitrate: 128
fps: 30
preset: fast
CBR: no
CFR: no
max bitrate: 4000
buffer size: 1200
quality: 10
New Scene
bufferTime: 3125, outputRateWindowTime: 1000, dropThreshold: 3625
Total frames rendered: 1556, number of frames that lagged: 70 (4.50%) (it's okay for some frames to lag)
Loading up D3D10...
Audio Encoding: AAC
bitrate: 128
fps: 30
preset: veryfast
CBR: no
CFR: no
max bitrate: 4000
buffer size: 1200
quality: 10
bufferTime: 1614, outputRateWindowTime: 1000, dropThreshold: 2114
Total frames rendered: 3362, number of frames that lagged: 7 (0.21%) (it's okay for some frames to lag)
Loading up D3D10...
Audio Encoding: AAC
bitrate: 128
Using bitmap image
fps: 30
preset: veryfast
CBR: no
CFR: no
max bitrate: 4000
buffer size: 1200
quality: 10
Total frames rendered: 189, number of frames that lagged: 0 (0.00%) (it's okay for some frames to lag)
Loading up D3D10...
Audio Encoding: AAC
bitrate: 128
Using bitmap image
Using text output
fps: 30
preset: veryfast
CBR: no
CFR: no
max bitrate: 4000
buffer size: 1200
quality: 10
New Scene
Total frames rendered: 32305, number of frames that lagged: 30 (0.09%) (it's okay for some frames to lag)
Loading up D3D10...
Audio Encoding: AAC
bitrate: 128
fps: 30
preset: veryfast
CBR: no
CFR: no
max bitrate: 4000
buffer size: 1200
quality: 10
bufferTime: 1420, outputRateWindowTime: 1000, dropThreshold: 1920
Total frames rendered: 12624, number of frames that lagged: 12 (0.10%) (it's okay for some frames to lag)
Output resolution: 852x480
Loading up D3D10...
Audio Encoding: AAC
bitrate: 128
fps: 30
width: 852, height: 480
preset: veryfast
CBR: no
CFR: no
max bitrate: 4000
buffer size: 1200
quality: 10
bufferTime: 1416, outputRateWindowTime: 1000, dropThreshold: 1916
Total frames rendered: 13609, number of frames that lagged: 4 (0.03%) (it's okay for some frames to lag)
Loading up D3D10...
Audio Encoding: AAC
bitrate: 128
fps: 30
preset: veryfast
CBR: no
CFR: no
max bitrate: 4000
buffer size: 900
quality: 10
bufferTime: 1410, outputRateWindowTime: 1000, dropThreshold: 1910
Total frames rendered: 28798, number of frames that lagged: 11 (0.04%) (it's okay for some frames to lag)
Loading up D3D10...
Audio Encoding: AAC
bitrate: 128
fps: 30
preset: veryfast
CBR: no
CFR: no
max bitrate: 4000
buffer size: 2000
quality: 10
bufferTime: 1400, outputRateWindowTime: 1000, dropThreshold: 1900
Total frames rendered: 3885, number of frames that lagged: 4 (0.10%) (it's okay for some frames to lag)
Loading up D3D10...
Audio Encoding: AAC
bitrate: 128
fps: 30
preset: veryfast
CBR: no
CFR: no
max bitrate: 3000
buffer size: 3000
quality: 10
bufferTime: 1975, outputRateWindowTime: 1000, dropThreshold: 2475
Total frames rendered: 1953, number of frames that lagged: 4 (0.20%) (it's okay for some frames to lag)
Loading up D3D10...
Audio Encoding: AAC
bitrate: 128
fps: 30
preset: veryfast
CBR: no
CFR: no
max bitrate: 3000
buffer size: 1500
quality: 10
bufferTime: 1407, outputRateWindowTime: 1000, dropThreshold: 1907
Total frames rendered: 1918, number of frames that lagged: 4 (0.21%) (it's okay for some frames to lag)
Loading up D3D10...
Audio Encoding: AAC
bitrate: 128
fps: 30
preset: veryfast
CBR: no
CFR: no
max bitrate: 3500
buffer size: 1000
quality: 10
bufferTime: 1762, outputRateWindowTime: 1000, dropThreshold: 2262
Total frames rendered: 67427, number of frames that lagged: 40 (0.06%) (it's okay for some frames to lag)
Loading up D3D10...
Audio Encoding: AAC
bitrate: 128
fps: 30
preset: veryfast
CBR: no
CFR: no
max bitrate: 5000
buffer size: 1100
quality: 10
bufferTime: 1421, outputRateWindowTime: 1000, dropThreshold: 1921
Total frames rendered: 21758, number of frames that lagged: 14 (0.06%) (it's okay for some frames to lag)
Loading up D3D10...
Audio Encoding: AAC
bitrate: 128
fps: 30
preset: veryfast
CBR: no
CFR: no
max bitrate: 5000
buffer size: 3000
quality: 10
bufferTime: 1932, outputRateWindowTime: 1000, dropThreshold: 2432
Total frames rendered: 1743, number of frames that lagged: 4 (0.23%) (it's okay for some frames to lag)
Loading up D3D10...
Audio Encoding: AAC
bitrate: 128
fps: 30
preset: veryfast
CBR: no
CFR: no
max bitrate: 3000
buffer size: 3000
quality: 10
bufferTime: 5479, outputRateWindowTime: 1000, dropThreshold: 5979
Total frames rendered: 1032, number of frames that lagged: 6 (0.58%) (it's okay for some frames to lag)
Loading up D3D10...
Audio Encoding: AAC
bitrate: 128
fps: 30
preset: veryfast
CBR: no
CFR: no
max bitrate: 5000
buffer size: 1500
quality: 10
bufferTime: 1485, outputRateWindowTime: 1000, dropThreshold: 1985
Total frames rendered: 6189, number of frames that lagged: 8 (0.13%) (it's okay for some frames to lag)
Loading up D3D10...
Audio Encoding: AAC
bitrate: 128
fps: 30
preset: veryfast
CBR: no
CFR: no
max bitrate: 5000
buffer size: 1500
quality: 10
bufferTime: 1408, outputRateWindowTime: 1000, dropThreshold: 1908
Total frames rendered: 3314, number of frames that lagged: 6 (0.18%) (it's okay for some frames to lag)
Loading up D3D10...
Audio Encoding: AAC
bitrate: 128
fps: 30
preset: fast
CBR: no
CFR: no
max bitrate: 3500
buffer size: 1000
quality: 10
bufferTime: 4752, outputRateWindowTime: 1000, dropThreshold: 5252
Total frames rendered: 1771, number of frames that lagged: 3 (0.17%) (it's okay for some frames to lag)
Loading up D3D10...
Audio Encoding: AAC
bitrate: 128
fps: 30
preset: fast
CBR: no
CFR: no
max bitrate: 3500
buffer size: 1000
quality: 10
bufferTime: 1423, outputRateWindowTime: 1000, dropThreshold: 1923
Total frames rendered: 6551, number of frames that lagged: 5 (0.08%) (it's okay for some frames to lag)
Loading up D3D10...
Audio Encoding: AAC
bitrate: 128
fps: 30
preset: fast
CBR: no
CFR: no
max bitrate: 5000
buffer size: 1000
quality: 10
bufferTime: 5058, outputRateWindowTime: 1000, dropThreshold: 5558
RTMPPublisher::BufferedSend: Socket buffer is full (655648 / 656384 bytes), waiting to send 4097 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (654713 / 656384 bytes), waiting to send 4104 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (653348 / 656384 bytes), waiting to send 4097 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (654254 / 656384 bytes), waiting to send 4097 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (656320 / 656384 bytes), waiting to send 4097 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (654539 / 656384 bytes), waiting to send 2480 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (656171 / 656384 bytes), waiting to send 4097 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (652826 / 656384 bytes), waiting to send 4097 bytes
New Scene
New Scene
RTMPPublisher::BufferedSend: Socket buffer is full (653043 / 656384 bytes), waiting to send 4097 bytes
RTMPPublisher::BufferedSend: Increasing socket send buffer to ISB 262144
New Scene
Using text output
Using bitmap image
Total frames rendered: 62253, number of frames that lagged: 1583 (2.54%) (it's okay for some frames to lag)
Number of b-frames dropped: 27 (0.021%), Number of p-frames dropped: 77 (0.061%), Total 104 (0.082%)
Loading up D3D10...
Audio Encoding: AAC
bitrate: 128
Using text output
Using bitmap image
fps: 30
preset: veryfast
CBR: no
CFR: no
max bitrate: 3000
buffer size: 5000
quality: 10
bufferTime: 1449, outputRateWindowTime: 1000, dropThreshold: 1949
New Scene
Total frames rendered: 64358, number of frames that lagged: 52 (0.08%) (it's okay for some frames to lag)
Loading up D3D10...
Audio Encoding: AAC
bitrate: 128
fps: 30
preset: veryfast
CBR: no
CFR: no
max bitrate: 3000
buffer size: 6500
quality: 10
bufferTime: 1747, outputRateWindowTime: 1000, dropThreshold: 2247
RTMPPublisher::BufferedSend: Socket buffer is full (398702 / 400384 bytes), waiting to send 4097 bytes
Total frames rendered: 2303, number of frames that lagged: 7 (0.30%) (it's okay for some frames to lag)
Loading up D3D10...
Audio Encoding: AAC
bitrate: 128
fps: 30
preset: veryfast
CBR: no
CFR: no
max bitrate: 3000
buffer size: 5000
quality: 10
New Scene
New Scene
Total frames rendered: 44293, number of frames that lagged: 140 (0.32%) (it's okay for some frames to lag)
Loading up D3D10...
Audio Encoding: AAC
bitrate: 128
fps: 30
preset: veryfast
CBR: no
CFR: no
max bitrate: 2500
buffer size: 4300
quality: 10
bufferTime: 1439, outputRateWindowTime: 1000, dropThreshold: 1939
Total frames rendered: 1228, number of frames that lagged: 4 (0.33%) (it's okay for some frames to lag)
Loading up D3D10...
Audio Encoding: AAC
bitrate: 128
fps: 30
preset: veryfast
CBR: no
CFR: no
max bitrate: 3500
buffer size: 5500
quality: 10
bufferTime: 1448, outputRateWindowTime: 1000, dropThreshold: 1948
RTMPPublisher::BufferedSend: Socket buffer is full (463784 / 463872 bytes), waiting to send 338 bytes
New Scene
New Scene
Using text output
Using bitmap image
Total frames rendered: 56565, number of frames that lagged: 29 (0.05%) (it's okay for some frames to lag)
Loading up D3D10...
Audio Encoding: AAC
bitrate: 128
fps: 30
preset: veryfast
CBR: no
CFR: no
max bitrate: 3500
buffer size: 5500
quality: 10
Total frames rendered: 4457, number of frames that lagged: 3 (0.07%) (it's okay for some frames to lag)
Loading up D3D10...
Audio Encoding: AAC
bitrate: 128
fps: 30
preset: veryfast
CBR: no
CFR: no
max bitrate: 5000
buffer size: 10000
quality: 10
Total frames rendered: 1735, number of frames that lagged: 16 (0.92%) (it's okay for some frames to lag)
Loading up D3D10...
Audio Encoding: AAC
bitrate: 128
fps: 30
preset: veryfast
CBR: no
CFR: no
max bitrate: 5000
buffer size: 10000
quality: 10
Total frames rendered: 592, number of frames that lagged: 5 (0.84%) (it's okay for some frames to lag)
Loading up D3D10...
Audio Encoding: AAC
bitrate: 128
fps: 30
preset: veryfast
CBR: no
CFR: no
max bitrate: 5000
buffer size: 10000
quality: 10
Total frames rendered: 1079, number of frames that lagged: 5 (0.46%) (it's okay for some frames to lag)
Loading up D3D10...
Audio Encoding: AAC
bitrate: 128
fps: 30
preset: veryfast
CBR: no
CFR: no
max bitrate: 5000
buffer size: 10000
quality: 10
bufferTime: 1403, outputRateWindowTime: 1000, dropThreshold: 1903
Total frames rendered: 3614, number of frames that lagged: 9 (0.25%) (it's okay for some frames to lag)
Output resolution: 640x360
Loading up D3D10...
Audio Encoding: AAC
bitrate: 128
fps: 40
width: 640, height: 360
preset: veryfast
CBR: no
CFR: no
max bitrate: 3000
buffer size: 5000
quality: 10
bufferTime: 1424, outputRateWindowTime: 1000, dropThreshold: 1924
Total frames rendered: 2858, number of frames that lagged: 12 (0.42%) (it's okay for some frames to lag)
Profiler results:
frame - [100%] [avg time: 5.278 ms] [avg calls per frame: 1] [children: 88%] [unaccounted: 12%]
| scene->Preprocess - [32.6%] [avg time: 1.718 ms] [avg calls per frame: 1]
| video encoding and uploading - [55.5%] [avg time: 2.929 ms] [avg calls per frame: 1] [children: 17%] [unaccounted: 38.5%]
| | CopyResource - [0.36%] [avg time: 0.019 ms] [avg calls per frame: 0]
| | conversion to 4:2:0 - [0.227%] [avg time: 0.012 ms] [avg calls per frame: 0]
| | call to encoder - [16.2%] [avg time: 0.854 ms] [avg calls per frame: 0]
| | sending stuff out - [0.208%] [avg time: 0.011 ms] [avg calls per frame: 0]
