Question / Help Help me with settings please
Haaacee
Hello. I've stream for quite a while but now my friends and viewers are complaining about that either the stream laggs or that the stream have a bad image. I can't seem to find the correct settings. My computer specs are:
NVIDIA GeForce GTX 550 Ti
Inter(R) Core(TM) i3-2100 CPU @ 3-10GHz
Though I stream from a Capture Card that I have chosen as a Video Capture Device. So the graphics card shouldn't make a difference. My Capture Card got the name : AverMedia C985 Live Gamer HD
I stream League of Legends and when I dont stream I got around 120 fps with a ping on around 30-40, while streaming I got 50-70 fps and around 40-50 ping. My current settings in OBS is:
Encoding :
Use CBR unchecked
Quality Balance 7
Max Bitrate (kb/s) 4000
Buffer Size (kbit) 4000
Video :
Video Adapter NVIDIA GeForce GTX 550 Ti
Custom Base Resolution 1920x1080
Downscale to 1280x720
Filter Bilinear (fastest)
FPS 60
Disable Aero unchecked
Then if I need some advanced settings I'd love to get some. Thank you!
