HELP! Inconsistent FPS/ Encoding Overload
tsquared35
Can anybody help guide me in the right direction? I am using OBS to record Zoom meetings and cannot maintain even 30 FPS and occasionally will get the encoding overload message in the bottom. My laptop specifications are below and I am attaching a log. Internet upload is 386/ download is 23.3 with 21 ms latency.
Device name DESKTOP-FVEB0OR
Processor 11th Gen Intel(R) Core(TM) i7-1165G7 @ 2.80GHz 2.80 GHz
Installed RAM 16.0 GB (15.7 GB usable)
Device ID 79106513-DBA9-494C-ABC3-C0D9E81777A1
Product ID 00325-97220-91109-AAOEM
System type 64-bit operating system, x64-based processor
Pen and touch Touch support with 10 touch points
  • 2023-03-07 08-04-52.txt
rockbottom
I'm running 29.0.2 with the latest driver on 12th gen, no issues here. The driver you have installed appears to be from 18 months ago, it needs to be updated if you want to use the latest version of OBS.
tsquared35
Just updated the driver and still getting drops in frames, here is the latest log file. Thanks for your help.
  • 2023-03-07 18-50-13.txt
rockbottom
Getting closer but that's not a new driver, it's from June 2022.
18:50:13.570: Adapter 1: Intel(R) Iris(R) Xe Graphics
18:50:13.570: Dedicated VRAM: 134217728
18:50:13.570: Shared VRAM: 4149628928
18:50:13.570: PCI ID: 8086:9a49
18:50:13.570: Driver Version: 30.0.101.1692
This is the new driver:
18:55:54.812: Driver Version: 31.0.101.4146
