I cann't stream FIFA 13 without lags.
http://ru.twitch.tv/kea6969/videos?kind=past_broadcasts
It my two broadcasts, with 30 fps and 60 fps.
If i set 60 fps, quality of stream not bad, but i see permanent freeze in game
If i set 30 fps, i see some freeze on stream and sliightly freeze in game
What's wrong?
What's wrong?
Open Broadcaster Software v0.472b - 64bit ( ^ω^)
CPU Name: Intel(R) Core(TM) i5-3570K CPU @ 3.40GHz
CPU Speed: 3502MHz
Physical Memory: 8144MB Total, 6341MB Free
stepping id: 9, model 10, family 6, type 0, extmodel 1, extfamily 0, HTT 1, logical cores 4, total cores 4
Aero is Disabled
Adapter 1
Video Adapter: NVIDIA GeForce GTX 670
Video Adapter Dedicated Video Memory: 2091581440
Video Adapter Shared System Memory: 2147479552
Using fixed low latency mode, factor 20
Base resolution: 1920x1080
Output resolution: 1280x720
Loading up D3D10...
Playback device Default
Using desktop audio input: Динамики (Аудио устройства USB)
Audio Encoding: MP3
bitrate: 128
Using graphics capture
x264: profile High, level 3.2
Video Encoding: x264
fps: 60
width: 1280, height: 720
preset: veryfast
CBR: no
CFR: no
max bitrate: 2900
buffer size: 2900
quality: 7
SharedTexCapture hooked
Server selection: rtmp://live-ams.justin.tv/app
bufferTime: 2392, outputRateWindowTime: 1000, dropThreshold: 2892
Total frames rendered: 4019, number of frames that lagged: 1 (0.02%) (it's okay for some frames to lag)
RTMPPublisher::SocketLoop: Aborting due to loop exit
x264: frame I:16 Avg QP:24.50 size: 52554
x264: frame P:1072 Avg QP:28.26 size: 6035
x264: frame B:2882 Avg QP:32.28 size: 868
x264: consecutive B-frames: 2.1% 0.4% 8.9% 88.6%
x264: mb I I16..4: 23.6% 57.9% 18.4%
x264: mb P I16..4: 4.0% 2.1% 0.1% P16..4: 24.8% 6.9% 2.2% 0.0% 0.0% skip:59.9%
x264: mb B I16..4: 0.1% 0.0% 0.0% B16..8: 7.0% 1.5% 0.1% direct: 0.4% skip:90.9% L0:40.1% L1:48.8% BI:11.1%
x264: 8x8 transform intra:36.6% inter:33.7%
x264: coded y,uvDC,uvAC intra: 42.5% 14.7% 4.9% inter: 2.0% 0.9% 0.2%
x264: i16 v,h,dc,p: 12% 68% 17% 4%
x264: i8 v,h,dc,ddl,ddr,vr,hd,vl,hu: 6% 32% 33% 4% 4% 3% 6% 3% 8%
x264: i4 v,h,dc,ddl,ddr,vr,hd,vl,hu: 16% 32% 20% 6% 4% 5% 5% 5% 6%
x264: i8c dc,h,v,p: 55% 37% 7% 1%
x264: Weighted P-Frames: Y:2.0% UV:0.7%
x264: kb/s:1186.32
Loading up D3D10...
Audio Encoding: MP3
bitrate: 128
x264: profile High, level 3.1
fps: 30
preset: veryfast
CBR: no
CFR: no
max bitrate: 2900
buffer size: 2900
quality: 7
bufferTime: 2407, outputRateWindowTime: 1000, dropThreshold: 2907
Total frames rendered: 593, number of frames that lagged: 0 (0.00%) (it's okay for some frames to lag)
x264: frame I:3 Avg QP:23.67 size: 55634
x264: frame P:174 Avg QP:26.03 size: 10331
x264: frame B:380 Avg QP:29.09 size: 1393
x264: consecutive B-frames: 5.0% 5.4% 18.2% 71.4%
x264: mb I I16..4: 25.9% 42.6% 31.5%
x264: mb P I16..4: 5.7% 5.3% 0.5% P16..4: 25.8% 8.6% 3.1% 0.0% 0.0% skip:51.1%
x264: mb B I16..4: 0.3% 0.1% 0.0% B16..8: 7.4% 2.0% 0.1% direct: 1.3% skip:88.7% L0:37.0% L1:51.9% BI:11.1%
x264: 8x8 transform intra:44.2% inter:35.2%
x264: coded y,uvDC,uvAC intra: 40.9% 19.3% 6.6% inter: 4.4% 2.1% 0.2%
x264: i16 v,h,dc,p: 19% 56% 20% 5%
x264: i8 v,h,dc,ddl,ddr,vr,hd,vl,hu: 10% 39% 29% 3% 3% 2% 6% 2% 6%
x264: i4 v,h,dc,ddl,ddr,vr,hd,vl,hu: 20% 31% 17% 5% 5% 5% 6% 5% 6%
x264: i8c dc,h,v,p: 56% 34% 9% 1%
x264: Weighted P-Frames: Y:8.6% UV:5.2%
x264: kb/s:1074.47
Loading up D3D10...
Audio Encoding: MP3
bitrate: 128
fps: 30
preset: veryfast
CBR: no
CFR: no
max bitrate: 2900
buffer size: 2900
quality: 7
bufferTime: 2380, outputRateWindowTime: 1000, dropThreshold: 2880
Total frames rendered: 1243, number of frames that lagged: 0 (0.00%) (it's okay for some frames to lag)
x264: frame I:5 Avg QP:22.60 size: 65086
x264: frame P:366 Avg QP:26.03 size: 9916
x264: frame B:836 Avg QP:30.42 size: 1953
x264: consecutive B-frames: 3.6% 2.2% 29.3% 64.9%
x264: mb I I16..4: 21.4% 57.5% 21.2%
x264: mb P I16..4: 5.3% 4.2% 0.5% P16..4: 31.6% 9.1% 3.0% 0.0% 0.0% skip:46.4%
x264: mb B I16..4: 0.4% 0.1% 0.0% B16..8: 12.7% 3.0% 0.2% direct: 1.0% skip:82.6% L0:41.9% L1:50.0% BI: 8.1%
x264: 8x8 transform intra:41.5% inter:35.0%
x264: coded y,uvDC,uvAC intra: 43.1% 16.6% 5.2% inter: 4.2% 1.7% 0.3%
x264: i16 v,h,dc,p: 14% 61% 19% 5%
x264: i8 v,h,dc,ddl,ddr,vr,hd,vl,hu: 7% 35% 31% 4% 4% 3% 6% 3% 7%
x264: i4 v,h,dc,ddl,ddr,vr,hd,vl,hu: 15% 27% 24% 6% 5% 6% 6% 5% 6%
x264: i8c dc,h,v,p: 54% 37% 8% 1%
x264: Weighted P-Frames: Y:7.4% UV:5.2%
x264: kb/s:1110.98
Profiler results:
frame - [100%] [avg time: 1.676 ms] [avg calls per frame: 1] [children: 72%] [unaccounted: 28%]
| scene->Preprocess - [0.179%] [avg time: 0.003 ms] [avg calls per frame: 1]
| video encoding and uploading - [71.8%] [avg time: 1.204 ms] [avg calls per frame: 1] [children: 57.5%] [unaccounted: 14.4%]
| | CopyResource - [1.19%] [avg time: 0.02 ms] [avg calls per frame: 0]
| | conversion to 4:2:0 - [0.239%] [avg time: 0.004 ms] [avg calls per frame: 0]
| | call to encoder - [55.4%] [avg time: 0.929 ms] [avg calls per frame: 0]
| | sending stuff out - [0.597%] [avg time: 0.01 ms] [avg calls per frame: 0]
