Question / Help Having Issues setting up a stream
Willben20
I'm trying to start a live playthrough of Might and Magic VI (6, if you don't know Roman Numerals) and the only way I could get the video to be captured is to do 'Monitor Capture' which it has the desktop at full screen on the video, but when I go into the game the screen shrinks to a small portion of the video screen in the upper left-hand corner. I've been trying to fix it, but I haven't the slightest clue how.
If you want a visual to help understand what I'm saying, just go to my latest 'Past Broadcasts' on my Twitch account, it'll all be from today (if for any reason these forums are slow, the day is 7/28/2013 Or July 28th)
My Twitch account is... www.Twitch.tv/Willben20 (I like to use the same username if I can)
Kharay
I can imagine why Monitor Capture would be the most immediate way to stream it; I'd imagine M&M 6 not having a windowed mode. ;)
However, what are your PCs specs like? Because I'd like to offer an alternative -- Run a Virtual Machine (running Windows XP), inside of a Window. And inside of that Virtual Windows XP, run M&M 6 as normal. And simply capture the Virtual XP in OBS (with Window Capture and Aero Enabled).
Willben20
To be honest, I don't really remember how to check the specs =P
I'm a little ashamed to admit that as much of a gamer I am, I know next to nothing about computers.
But yeah, I'm pretty sure your right that M&M6 doesn't have a windowed mode. And that alternative sounds pretty good. But I know my Laptop runs Windows 7, so idk if it'd be able to work or not.
Kharay
Errrrh... the Windows version has very little to do with it; I was running VMs just fine on Windows XP. :P Anyhow... could you post a recent log of OBS? Amongst other things, it does list your PCs specifications. ;)
Willben20
Copy/Pasted from one of the logs with todays date
12:02:07: Open Broadcaster Software v0.541b - 32bit (´・ω・`)
12:02:07: -------------------------------
12:02:07: CPU Name: Intel(R) Pentium(R) CPU B950 @ 2.10GHz
12:02:07: CPU Speed: 2095MHz
12:02:07: Physical Memory:  4095MB Total, 3851MB Free
12:02:07: stepping id: 7, model 10, family 6, type 0, extmodel 1, extfamily 0, HTT 1, logical cores 2, total cores 2
12:02:07: monitor 1: pos={0, 0}, size={1366, 768}
12:02:07: Windows Version: 6.1 Build 7601 S
12:02:07: Aero is Enabled
12:02:07: OBS Modules:
12:02:07: Base Address     Module
12:02:07: 00890000         OBS.exe
12:02:07: 5CA90000         OBSApi.dll
12:02:07: 610C0000         DShowPlugin.dll
12:02:07: 63000000         GraphicsCapture.dll
12:02:07: 62F70000         NoiseGate.dll
12:02:07: 62AC0000         PSVPlugin.dll
12:02:07: ------------------------------------------
12:02:07: Adapter 1
12:02:07:   Video Adapter: Intel(R) HD Graphics Family
12:02:07:   Video Adapter Dedicated Video Memory: 67108864
12:02:07:   Video Adapter Shared System Memory: 1711276032
12:02:07: =====Stream Start: 2013-07-28, 12:02:07===============================================
12:02:07:   Multithreaded optimizations: On
12:02:07:   Base resolution: 1366x768
12:02:07:   Output resolution: 1364x768
12:02:08: Loading up D3D10...
12:02:08: Playback device Default
12:02:08: ------------------------------------------
12:02:08: Using desktop audio input: Speakers (Realtek High Definition Audio)
12:02:08: Using auxilary audio input: Microphone (Realtek High Definition Audio)
12:02:08: Audio Encoding: AAC
12:02:08:     bitrate: 128
12:02:08: Using graphics capture
12:02:08: Video Encoding: x264
12:02:08:     fps: 30
12:02:08:     width: 1364, height: 768
12:02:08:     preset: veryfast
12:02:08:     CBR: yes
12:02:08:     CFR: no
12:02:08:     max bitrate: 1000
12:02:15: Total frames rendered: 198, number of frames that lagged: 4 (2.02%) (it's okay for some frames to lag)
12:02:15: =====Stream End: 2013-07-28, 12:02:15=================================================
12:02:34: =====Stream Start: 2013-07-28, 12:02:34===============================================
12:02:34:   Multithreaded optimizations: On
12:02:34:   Base resolution: 1366x768
12:02:34:   Output resolution: 1364x768
12:02:34: ------------------------------------------
12:02:34: Loading up D3D10...
12:02:34: Playback device Default
12:02:34: Using desktop audio input: Speakers (Realtek High Definition Audio)
12:02:34: Using auxilary audio input: Microphone (Realtek High Definition Audio)
12:02:34: Audio Encoding: AAC
12:02:34:     bitrate: 128
12:02:34: Using graphics capture
12:02:34: Video Encoding: x264
12:02:34:     fps: 30
12:02:34:     width: 1364, height: 768
12:02:34:     preset: veryfast
12:02:34:     CBR: yes
12:02:34:     CFR: no
12:02:34:     max bitrate: 1000
12:02:39: Total frames rendered: 156, number of frames that lagged: 0 (0.00%) (it's okay for some frames to lag)
12:02:39: =====Stream End: 2013-07-28, 12:02:39=================================================
12:02:46: =====Stream Start: 2013-07-28, 12:02:46===============================================
12:02:46:   Multithreaded optimizations: On
12:02:46:   Base resolution: 1366x768
12:02:46:   Output resolution: 1364x768
12:02:46: ------------------------------------------
12:02:46: Loading up D3D10...
12:02:46: Playback device Default
12:02:46: Using desktop audio input: Speakers (Realtek High Definition Audio)
12:02:46: Using auxilary audio input: Microphone (Realtek High Definition Audio)
12:02:46: Audio Encoding: AAC
12:02:46:     bitrate: 128
12:02:46: Using graphics capture
12:02:46: Video Encoding: x264
12:02:46:     fps: 30
12:02:46:     width: 1364, height: 768
12:02:46:     preset: veryfast
12:02:46:     CBR: yes
12:02:46:     CFR: no
12:02:46:     max bitrate: 1000
12:02:47: Using RTMP service: Twitch / Justin.tv
12:02:47:   Server selection: rtmp://live-jfk.justin.tv/app
12:02:49: SO_SNDBUF was at 8192
12:02:49: SO_SNDBUF is now 65536
12:02:54: RTMPPublisher::BufferedSend: Increasing socket send buffer to ISB 131072
12:02:55: RTMPPublisher::BufferedSend: Increasing socket send buffer to ISB 262144
12:02:57: RTMPPublisher::BufferedSend: Increasing socket send buffer to ISB 524288
12:05:32: Capture window 0x00050532 invalid or changing, terminating capture
12:05:34: Total frames rendered: 4943, number of frames that lagged: 7 (0.14%) (it's okay for some frames to lag)
12:05:34: RTMPPublisher::SocketLoop: Aborting due to bStopping
12:05:34: Number of times waited to send: 113, Waited for a total of 395916 bytes
12:05:34: Number of b-frames dropped: 548 (11%), Number of p-frames dropped: 117 (2.4%), Total 665 (14%)
12:05:34: =====Stream End: 2013-07-28, 12:05:34=================================================
12:11:40: =====Stream Start: 2013-07-28, 12:11:40===============================================
12:11:40:   Multithreaded optimizations: On
12:11:40:   Base resolution: 1366x768
12:11:40:   Output resolution: 1364x768
12:11:40: ------------------------------------------
12:11:40: Loading up D3D10...
12:11:41: Playback device Default
12:11:41: ------------------------------------------
12:11:41: Using desktop audio input: Speakers (Realtek High Definition Audio)
12:11:41: Using auxilary audio input: Microphone (Realtek High Definition Audio)
12:11:41: Audio Encoding: AAC
12:11:41:     bitrate: 128
12:11:41: Using Monitor Capture
12:11:41: Video Encoding: x264
12:11:41:     fps: 30
12:11:41:     width: 1364, height: 768
12:11:41:     preset: veryfast
12:11:41:     CBR: yes
12:11:41:     CFR: no
12:11:41:     max bitrate: 1000
12:11:42: Using RTMP service: Twitch / Justin.tv
12:11:42:   Server selection: rtmp://live-jfk.justin.tv/app
12:11:44: SO_SNDBUF was at 8192
12:11:44: SO_SNDBUF is now 65536
12:14:20: Total frames rendered: 4649, number of frames that lagged: 222 (4.78%) (it's okay for some frames to lag)
12:14:20: okay, this is strange
12:14:20: RTMPPublisher::SocketLoop: Aborting due to loop exit
12:14:20: librtmp error: WriteN, RTMP send error 10035 (79 bytes)
12:14:20: librtmp error: WriteN, RTMP send error 10038 (42 bytes)
12:14:20: Number of times waited to send: 116, Waited for a total of 384619 bytes
12:14:20: Number of b-frames dropped: 405 (9%), Number of p-frames dropped: 347 (7.7%), Total 752 (17%)
12:14:20: =====Stream End: 2013-07-28, 12:14:20=================================================
12:19:48: =====Stream Start: 2013-07-28, 12:19:48===============================================
12:19:48:   Multithreaded optimizations: On
12:19:48:   Base resolution: 1366x768
12:19:48:   Output resolution: 1364x768
12:19:48: ------------------------------------------
12:19:48: Loading up D3D10...
12:19:48: Playback device Default
12:19:48: Using desktop audio input: Speakers (Realtek High Definition Audio)
12:19:48: Using auxilary audio input: Microphone (Realtek High Definition Audio)
12:19:48: Audio Encoding: AAC
12:19:48:     bitrate: 128
12:19:48: Using Monitor Capture
12:19:48: Video Encoding: x264
12:19:48:     fps: 30
12:19:48:     width: 1364, height: 768
12:19:48:     preset: veryfast
12:19:48:     CBR: yes
12:19:48:     CFR: no
12:19:48:     max bitrate: 1000
12:19:50: Using RTMP service: Twitch / Justin.tv
12:19:50:   Server selection: rtmp://live-jfk.justin.tv/app
12:19:52: SO_SNDBUF was at 8192
12:19:52: SO_SNDBUF is now 65536
12:20:07: RTMPPublisher::BufferedSend: Increasing socket send buffer to ISB 524288
12:20:14: RTMPPublisher::BufferedSend: Increasing socket send buffer to ISB 1048576
12:20:52: Total frames rendered: 1777, number of frames that lagged: 211 (11.87%) (it's okay for some frames to lag)
12:20:52: RTMPPublisher::SocketLoop: Aborting due to bStopping
12:20:52: Number of times waited to send: 7, Waited for a total of 21405 bytes
12:20:52: Number of b-frames dropped: 25 (1.5%), Number of p-frames dropped: 31 (1.9%), Total 56 (3.4%)
12:20:52: =====Stream End: 2013-07-28, 12:20:52=================================================
12:20:56:
12:20:56: Profiler results:
12:20:56:
12:20:56: ==============================================================
12:20:56: frame - [100%] [avg time: 10.339 ms (cpu time: avg 3.833 ms, total 44943.9 ms)] [avg calls per frame: 1] [children: 93.8%] [unaccounted: 6.19%]
12:20:56: | scene->Preprocess - [39.1%] [avg time: 4.041 ms (cpu time: avg 1.542 ms, total 18080.5 ms)] [avg calls per frame: 1]
12:20:56: | video encoding and uploading - [54.7%] [avg time: 5.658 ms (cpu time: avg 2.028 ms, total 23774.6 ms)] [avg calls per frame: 1] [children: 53.3%] [unaccounted: 1.4%]
12:20:56: | | CopyResource - [1.09%] [avg time: 0.113 ms (cpu time: avg 0.055 ms, total 655.206 ms)] [avg calls per frame: 0]
12:20:56: | | conversion to 4:2:0 - [6.34%] [avg time: 0.656 ms (cpu time: avg 0.007 ms, total 93.601 ms)] [avg calls per frame: 0]
12:20:56: | | call to encoder - [45.6%] [avg time: 4.718 ms (cpu time: avg 1.918 ms, total 22495.3 ms)] [avg calls per frame: 0]
12:20:56: | | sending stuff out - [0.251%] [avg time: 0.026 ms (cpu time: avg 0.017 ms, total 202.801 ms)] [avg calls per frame: 0]
12:20:56: | Convert444Threads - [331%] [avg time: 34.209 ms (cpu time: avg 1.409 ms, total 16520.5 ms)] [avg calls per frame: 0]
12:20:56:
(jim edit: code tags are really nice, surround your logs in them and you get this. makes the forum a bit more clean)
Willben20
Sweet, thank you. It says I need to set the desktop to 16bit in order to switch back and forth (as shown in attachment)
Woohoo, I can do what I wanted to do now =)
