Question / Help Green -> Yellow -> Red light - Frames Fly [RESOLVED]
Xarox
Then it goes back to green again. This occurs every 5-10 seconds or so. It's supposed to stay green, right? Or maybe I'm not understanding this program at all? lol
I just want to point out that in November/December when I started doing this, I had no issues at all streaming with a 1680*1050 resolution. I started getting issues right after new years. Maybe, what my problem is, is that I've updated to the newer versions without uninstalling the older one first?
I did a series of tests today, I added them here. I can look at the light and see it go to red, and the frames drop like mad. Even with all tests. Very frustrating. Not a single test stayed green. And I've tried switching servers also. Not during this test though.
Otherwise, is it possible to get a step by step instruction to completely wipe everything OBS related on the computer and make a complete fresh re-install?
Thanks in advance to any help! :)
Open Broadcaster Software v0.47a - 32bit (´・ω・`)
CPU Name: AMD Phenom(tm) II X4 965 Processor
CPU Speed: 3411MHz
Physical Memory:  4095MB Total, 4095MB Free
stepping id: 3, model 4, family 15, type 0, extmodel 8, extfamily 0, HTT 1, logical cores 4, total cores 4
Aero is Enabled
Adapter 1
  Video Adapter: AMD Radeon HD 6800 Series
  Video Adapter Dedicated Video Memory: 1057464320
  Video Adapter Shared System Memory: 4025575424
  Base resolution: 1680x1050
  Output resolution: 1680x1050
Loading up D3D10...
Playback device {0.0.0.00000000}.{8a63e919-8496-4336-8caf-27d96e0ab1ae}
Using desktop audio input: Speakers (VIA High Definition Audio)
Using auxilary audio input: Microphone (VIA High Definition Audio)
Audio Encoding: AAC
    bitrate: 128
Video Encoding: x264
    fps: 30
    width: 1680, height: 1050
    preset: superfast
    CBR: no
    CFR: no
    max bitrate: 3500
    buffer size: 3500
    quality: 7
Total frames rendered: 108, number of frames that lagged: 0 (0.00%) (it's okay for some frames to lag)
Loading up D3D10...
Audio Encoding: AAC
    bitrate: 128
Using Window Capture
    fps: 30
    preset: superfast
    CBR: no
    CFR: no
    max bitrate: 3500
    buffer size: 3500
    quality: 7
Total frames rendered: 158, number of frames that lagged: 0 (0.00%) (it's okay for some frames to lag)
Loading up D3D10...
Audio Encoding: AAC
    bitrate: 128
    fps: 30
    preset: superfast
    CBR: no
    CFR: no
    max bitrate: 3500
    buffer size: 3500
    quality: 7
  Server selection: rtmp://live-lhr-backup.justin.tv/app
bufferTime: 2112, outputRateWindowTime: 1000, dropThreshold: 2612
RTMPPublisher::BufferedSend: Socket buffer is full (463367 / 463872 bytes), waiting to send 4097 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (460959 / 463872 bytes), waiting to send 4104 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (461096 / 463872 bytes), waiting to send 4097 bytes
RTMPPublisher::BufferedSend: Increasing socket send buffer to ISB 131072
RTMPPublisher::BufferedSend: Socket buffer is full (463695 / 463872 bytes), waiting to send 384 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (462734 / 463872 bytes), waiting to send 4104 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (463865 / 463872 bytes), waiting to send 398 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (460889 / 463872 bytes), waiting to send 4104 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (460192 / 463872 bytes), waiting to send 4097 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (461162 / 463872 bytes), waiting to send 4104 bytes
Total frames rendered: 1656, number of frames that lagged: 1 (0.06%) (it's okay for some frames to lag)
okay, this is strange
RTMPPublisher::SocketLoop: Aborting due to loop exit
librtmp error: WriteN, RTMP send error 10035 (79 bytes)
librtmp error: WriteN, RTMP send error 10038 (42 bytes)
Number of b-frames dropped: 314 (8%), Number of p-frames dropped: 184 (4.7%), Total 498 (13%)
Loading up D3D10...
Audio Encoding: AAC
    bitrate: 128
    fps: 30
    preset: veryfast
    CBR: no
    CFR: no
    max bitrate: 3500
    buffer size: 3500
    quality: 7
Total frames rendered: 99, number of frames that lagged: 0 (0.00%) (it's okay for some frames to lag)
Loading up D3D10...
Audio Encoding: AAC
    bitrate: 128
    fps: 30
    preset: veryfast
    CBR: no
    CFR: no
    max bitrate: 3500
    buffer size: 3500
    quality: 7
bufferTime: 2069, outputRateWindowTime: 1000, dropThreshold: 2569
RTMPPublisher::BufferedSend: Socket buffer is full (461566 / 463872 bytes), waiting to send 4097 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (463707 / 463872 bytes), waiting to send 397 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (460705 / 463872 bytes), waiting to send 4097 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (462873 / 463872 bytes), waiting to send 1714 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (459971 / 463872 bytes), waiting to send 4104 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (460922 / 463872 bytes), waiting to send 3952 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (463760 / 463872 bytes), waiting to send 375 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (463614 / 463872 bytes), waiting to send 4097 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (463567 / 463872 bytes), waiting to send 485 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (461997 / 463872 bytes), waiting to send 4097 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (462447 / 463872 bytes), waiting to send 4097 bytes
Total frames rendered: 4328, number of frames that lagged: 1 (0.02%) (it's okay for some frames to lag)
Number of b-frames dropped: 562 (5.4%), Number of p-frames dropped: 555 (5.3%), Total 1117 (11%)
  Output resolution: 1120x700
Loading up D3D10...
Audio Encoding: AAC
    bitrate: 128
    fps: 25
    width: 1120, height: 700
    preset: veryfast
    CBR: no
    CFR: no
    max bitrate: 4000
    buffer size: 4000
    quality: 7
Total frames rendered: 133, number of frames that lagged: 0 (0.00%) (it's okay for some frames to lag)
Loading up D3D10...
Audio Encoding: AAC
    bitrate: 128
    fps: 25
    preset: veryfast
    CBR: no
    CFR: no
    max bitrate: 4000
    buffer size: 4000
    quality: 7
bufferTime: 2217, outputRateWindowTime: 1000, dropThreshold: 2717
RTMPPublisher::BufferedSend: Socket buffer is full (525778 / 528384 bytes), waiting to send 4097 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (526042 / 528384 bytes), waiting to send 3886 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (528357 / 528384 bytes), waiting to send 354 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (525956 / 528384 bytes), waiting to send 4097 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (527143 / 528384 bytes), waiting to send 1286 bytes
RTMPPublisher::BufferedSend: Increasing socket send buffer to ISB 262144
RTMPPublisher::BufferedSend: Socket buffer is full (527720 / 528384 bytes), waiting to send 3926 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (528147 / 528384 bytes), waiting to send 4097 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (525896 / 528384 bytes), waiting to send 4104 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (528264 / 528384 bytes), waiting to send 4097 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (526538 / 528384 bytes), waiting to send 4097 bytes
Total frames rendered: 12188, number of frames that lagged: 3 (0.02%) (it's okay for some frames to lag)
Number of b-frames dropped: 277 (0.84%), Number of p-frames dropped: 267 (0.81%), Total 544 (1.6%)
Loading up D3D10...
Audio Encoding: AAC
    bitrate: 128
    fps: 25
    preset: faster
    CBR: no
    CFR: no
    max bitrate: 4000
    buffer size: 4000
    quality: 7
Loading up D3D10...
Audio Encoding: AAC
    bitrate: 128
    fps: 25
    preset: faster
    CBR: no
    CFR: no
    max bitrate: 4000
    buffer size: 4000
    quality: 7
bufferTime: 2121, outputRateWindowTime: 1000, dropThreshold: 2621
RTMPPublisher::BufferedSend: Socket buffer is full (524535 / 528384 bytes), waiting to send 4104 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (526193 / 528384 bytes), waiting to send 4104 bytes
Total frames rendered: 1635, number of frames that lagged: 1 (0.06%) (it's okay for some frames to lag)
Number of b-frames dropped: 126 (2.9%), Number of p-frames dropped: 133 (3.1%), Total 259 (6%)
Loading up D3D10...
Audio Encoding: AAC
    bitrate: 128
    fps: 25
    preset: veryfast
    CBR: no
    CFR: no
    max bitrate: 4000
    buffer size: 4000
    quality: 7
Syncing audio to video time
bufferTime: 2183, outputRateWindowTime: 1000, dropThreshold: 2683
RTMPPublisher::BufferedSend: Socket buffer is full (525435 / 528384 bytes), waiting to send 3782 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (524500 / 528384 bytes), waiting to send 4104 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (528288 / 528384 bytes), waiting to send 378 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (527237 / 528384 bytes), waiting to send 1333 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (528185 / 528384 bytes), waiting to send 367 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (525819 / 528384 bytes), waiting to send 4097 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (525220 / 528384 bytes), waiting to send 3587 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (527974 / 528384 bytes), waiting to send 1854 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (528376 / 528384 bytes), waiting to send 404 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (528320 / 528384 bytes), waiting to send 405 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (527988 / 528384 bytes), waiting to send 4104 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (524322 / 528384 bytes), waiting to send 4104 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (527664 / 528384 bytes), waiting to send 2436 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (526938 / 528384 bytes), waiting to send 4104 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (525947 / 528384 bytes), waiting to send 4097 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (528261 / 528384 bytes), waiting to send 4104 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (526352 / 528384 bytes), waiting to send 4097 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (524906 / 528384 bytes), waiting to send 4097 bytes
Total frames rendered: 20706, number of frames that lagged: 1 (0.00%) (it's okay for some frames to lag)
Number of b-frames dropped: 666 (1.2%), Number of p-frames dropped: 617 (1.1%), Total 1283 (2.3%)
  Output resolution: 840x524
Loading up D3D10...
Audio Encoding: AAC
    bitrate: 128
    fps: 30
    width: 840, height: 524
    preset: veryfast
    CBR: no
    CFR: no
    max bitrate: 4000
    buffer size: 4000
    quality: 10
bufferTime: 2147, outputRateWindowTime: 1000, dropThreshold: 2647
Total frames rendered: 142, number of frames that lagged: 0 (0.00%) (it's okay for some frames to lag)
Loading up D3D10...
Audio Encoding: AAC
    bitrate: 128
    fps: 30
    preset: veryfast
    CBR: no
    CFR: no
    max bitrate: 4000
    buffer size: 4000
    quality: 10
bufferTime: 2054, outputRateWindowTime: 1000, dropThreshold: 2554
RTMPPublisher::BufferedSend: Socket buffer is full (527452 / 528384 bytes), waiting to send 4097 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (528265 / 528384 bytes), waiting to send 837 bytes
Total frames rendered: 3450, number of frames that lagged: 0 (0.00%) (it's okay for some frames to lag)
Number of b-frames dropped: 100 (1.2%), Number of p-frames dropped: 52 (0.63%), Total 152 (1.8%)
  Multithreaded optimizations: Off
Loading up D3D10...
Audio Encoding: AAC
    bitrate: 128
    fps: 30
    preset: veryfast
    CBR: no
    CFR: no
    max bitrate: 4000
    buffer size: 4000
    quality: 10
bufferTime: 2101, outputRateWindowTime: 1000, dropThreshold: 2601
RTMPPublisher::BufferedSend: Socket buffer is full (527441 / 528384 bytes), waiting to send 1116 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (525878 / 528384 bytes), waiting to send 4097 bytes
RTMPPublisher::BufferedSend: Socket buffer is full (525742 / 528384 bytes), waiting to send 4104 bytes
Total frames rendered: 3151, number of frames that lagged: 0 (0.00%) (it's okay for some frames to lag)
Number of b-frames dropped: 164 (2.2%), Number of p-frames dropped: 174 (2.3%), Total 338 (4.5%)
Profiler results:
frame - [100%] [avg time: 4.265 ms] [avg calls per frame: 1] [children: 96.1%] [unaccounted: 3.87%]
| scene->Preprocess - [51.8%] [avg time: 2.21 ms] [avg calls per frame: 1]
| video encoding and uploading - [44.3%] [avg time: 1.89 ms] [avg calls per frame: 1] [children: 43.4%] [unaccounted: 0.961%]
| | CopyResource - [0.234%] [avg time: 0.01 ms] [avg calls per frame: 0]
| | conversion to 4:2:0 - [1.9%] [avg time: 0.081 ms] [avg calls per frame: 0]
| | call to encoder - [40.9%] [avg time: 1.743 ms] [avg calls per frame: 0]
| | sending stuff out - [0.352%] [avg time: 0.015 ms] [avg calls per frame: 0]
Grimio
Re: Green -> Yellow -> Red light - Frames Fly
Looks like the problem lies between you and the twitch server. You can try lowering the bitrate to around 3000 and see if it gets better.
R1CH
You could try using low latency mode to minimize bursting.
Xarox
Jim said:
The setting data is in %appdata% (paste that into your start/run), OBS folder, that's where all data is saved
Jim posted in a different thread answering my begging for help. :)
And, after the un-install and complete wipe of any OBS related files, I made a fresh re-install of OBS.
How did it work out? Well.... I'M BACK BABY!!!! :D
Running 1680*1050, quality 8, 4000/4000, 30fps... I had 3-5% frame losses for a 10 minute stream...
Then as a test, I lowered it 1,5 to 1120*700, quality 8, 4000/4000, 40fps... I had 0% frame losses...
I will try to up the quality to 10 and fps to 50, and see if that works out, just to see the quality.
All you helpers here, you are all awesome! This program will go FAR with people like you around! :)
Xarox
Xarox
Of course I cheered to soon.
Since the 9th, I've been in contact with my ISP to figure out why I get the network drops. After tests from their side and me doing tracerts, they came to the conclusion that the problem is not on their end. Their network is fine.
I'm still getting the Green -> Yellow -> Red lights every 3-5 seconds or so. I've taken screenshots yesterday to show what is going on while streaming EQ2 in charselect screen. There are no frame drops because I am not doing anything. But the network stability while using OBS is still acting up. I can however run anything in the background that will run smoothly with no hiccups on the network.
I just want to be able to stream, and it's not letting me. Very frustrating.
/Xarox
Xarox
This last picture is to show what is going on when I run OBS...
I don't know what to do anymore.
Xarox
Ok, this is interesting. Inkbot gave me an idea.
I used to be able to stream without noticing lag in my streams, so I went back to the version I used to use while streaming.
I think it was 0432a 64bit. (not 100% sure, could have been an earlier one)
Anyways, I downloaded, and tested running it. It did the same thing, shifting between the colors, BUT, super fast. (so fast that I never got to see the red color) Like it was on steroids. I lost about 200 frames during the 8 minutes I tested. Funny thing is, the stream lags I get today from framedrops I didn't get while testing this old version. You can't even notice the frame drops.
This is it. The setup was 4000/4000, 30fps, 1680*1050.
http://www.twitch.tv/storm_cloud/b/369708974
(Btw, excuse the chatter in the beginning, I had another stream running in the background)
Weird how that worked out, huh? :)
Xarox
Bensam123
I'm going to mirror this, unfortunately I took a break from streaming and I was only using preview mode. Now using the latest version about every 10 seconds I get lag spikes. Low latency mode doesn't do anything. Using CBR helps elevate them, but doesn't completely remove them.
When I was streaming in december I didn't have this issue. I also went back to a earlier version of OBS when things were working fine (.461) and it didn't seem to fix it. I was pretty sure this was a ISP issue, but if you're having issues too then it's starting to look like a trend.
My ISP doesn't shape my connection and I have a 4.2Mbps upload, I stream at 3.1. I tried going all the way down to 2Mbps for a max bitrate and it still does this, so that's whats conflicting about this.
I watched your stream and the quality and consistency looks fine. Just to clarify, this is lag on your machine and not on the stream? In other words you get lag in game and in the OBS window, but your stream is fluid. For me, I don't get stream lag, but my ping fluctuates on about a 10 second interval.
Xarox
I got massive frame drops after New Years, and it was clearly viewable in my stream. In my own view of the game while playing, I don't lag at all.
Happy to say though that the 0432a, 64bit version has been godsent for me, once I switched back to it. I still notice the color changes and some framedrops. In EQ1, rarely any drop at all, but in EQ2 the framedrops are more consistant. The funny thing about this is, is that you can't notice the framedrops in the stream, unless it's a massive drop that's going on which doesn't happen very often. Then you can notice the freeze in the stream.
So, for me I am very happy about switching back to this old version. I will still try out the new versions that's being released in the future, to see if any of them has fixes for me with the green/yellow/red switches, etc.
When the day comes and I can run with constant green light, I will be 100% happy. (Currently at 90%, because I have got it working, hehe :))
Bensam123
Hmmm, perhaps I'm experiencing a different issue from you then. Mine started around the same time frame though and has similar issues.
Xarox
Well, you do get the spikes which causes the frame drops, even at lower resolutions. That sounds like it's the main common issue.
The 0432a version kinda made those spikes come x10 times faster, but I never see them go into the red anymore unless it's a massive spike.
How do you check your stream? I've just now, when I switched to this older version, learned not to look at the lights and frame drops anymore on the OBS program. It was making me go insane, lol. I check the recorded session on twitch when I am done streaming.
Xarox
I give up... I've tried all these new cool versions, changing one thing to another... It just doesn't work for me... I really want to use them...
The only version that I stopped at, that I found that works is the 0432a, still... I get no framedrops... What changed between that version and later versions that made such huge horrible impact for me?
Xarox
EDIT!:
There is 1 thing that I have noticed, that is not in the new versions. I have it blank because that's what it's been as default, and I don't dare change it, lol. If it has anything to do with anything. :)
Xarox
I just want to apologize for my own stupidity.
I've been reading many times about minimize network impact, but never actually "seen" it. lol
Currently, I am streaming, using the latest test version, and using game capture. For the passed 42 minutes, I've had 0% drops. And the light, has remained green through out the entire time.
I don't know what the stream looks like, but I will check the video later. I bet it's great! :)
So, sorry again, for crying over nothing but my own blindness.
Xarox
EDIT... actually, let me correct myself... just realized I had a completely black screen. Apparently homm 6 can't be captured, so been streaming that for 40 minutes, lol... Anyways, switched to software capture, but still looks very good. The yellow "flicker" once in a while, no frame drops as of yet. :)
EDIT2... Streamed for another 1,5 hours... I dropped a whole wooping 3 frames during that time. That's a TON better than the couple 1000 I used to drop with these new versions... LOL
EDIT3... Friday morning! Conducted a few tests... Seems like the latest test version (473b v8)cannot stream Homm6 using game capture, but 472b can. If I start with the test version I get a black screen, then try 472b right after, it results in that 472b also get a black screen. But, if I make a new scene and only start that with 472b, and restart the game, then I can stream it. 473b version 8 breaks it every time. (tests were made with preview, not actual streaming)
Or, I am just doing something wrong, again! lol
EDIT4... Streamed homm6 for another 2 hours today (Friday) using 0.472b and game capture. 0% frame loss.
I am ecstatic!
I consider my issue resolved. I retitled the thread accordingly.
