GredBot
GredBot 0.5.6
CoMFliP
CoMFliP submitted a new resource:
GredBot - Free music bot for streamers with YouTube, Twitch integration, and OBS widget
GredBot — Music Bot for Streams
GredBot is a free and simple solution designed to enhance the quality of your live streams by adding music control features.
Key Features
  • Twitch Integration: interact with viewers through Channel Points
  • Track Management: request, skip, and control music directly from YouTube
  • Player Widget: use as a source in OBS or other streaming software
  • Filtering Options...
CoMFliP
CoMFliP updated GredBot with a new update entry:
GredBot v0.5.5
Main Changes:
  • Added alternative connections to program widgets via bridge files for embedding through streaming software.
  • Added the ability to save, delete, and load program data, as well as open its data directory in the system.
    You can find this option in the "Settings" tab under the "Files" section.
  • Added background logging. Log files are stored in the
    /logs
    folder inside the program’s data directory.
  • Added an option to hide...
CoMFliP
GredBot v0.5.6
Main Changes:
  • Added Twitch user search for adding users to block and whitelist lists
  • Updated timer for YouTube live streams
  • Added an option to enable or disable automatic channel points deduction
  • Changed the connection port for the control panel and the widget
  • When adding an active track to the blocklist, the player skips it and starts the next track if one is available in the playlist
  • When adding a user to the blocklist, the...
