Game Capture way too stretched
gergouwu
While I was nearing the finish line of setting up a stream overlay the final thing missing was the Game Capture itself. I added a Game Capture and added my game, but when I added it, I saw that OBS captures it in a really stretched not correct way. Ctrl + F doesn't work, it stretches it uncorrectly too. My Base Canvas Resolution is 1920 x 1080, which matches the game, and the Output Scaled Resolution is 1664 x 936 (still 16:9 aspect ratio). I'm not sure what the issue might be, but dragging the Game Capture by the red sides only makes it fit the screen height-wise, not wideness-wise. I'm stumped and am hoping that someone might be able to help with this. There's a screenshot of the problem aswell
Banyarola
I may not be right with this but have you tried Right Click on the source, Transform/Fit To Screen ???
Banyarola
I'm sorry but I have no idea...I'm sure someone else here can help....
If no one helps re-post the problem to get it to the top of the list..
