Frame rate problem on recording (frames are missing)
theomandard
Hi,
I record my video lessons with OBS. I only record, no stream.
My GH5 camera is plugged to my Mac with Elgato Camlink 4K and I also record my laptop screen.
I set 25fps.
But on my recordings, some frames are doubled so I don't have 25 frames but like 15 or 20.
Generally, at the beginning it's ok I have 25 frames but then the number decreases.
I thought it was due to my laptop bu I bought a very powerfull one recently : the Macbook Pro M1 Max 32 GPU and 32Go RAM.
You can see my recording settings on the photo.
It's a problem and I don't know how to fix that.
Thanks for your help,
Théo
