I have been trying to fix this frame lag issue for a while now and I have tried several solutions to this problem that I found on these forums, but none of them have worked so far. The CPU is overclocked to 4.5Ghz, the graphics card is overclocked, and the ram is overclocked to 1866.
I have tried the following solutions:
-Ran the game in windowed mode and full screen mode.
-Tried a lower bitrate (2000-2000, 3000-3000,4000-4000, etc...)
-Lowered the resolution down to 720p and down-scaling the resolution to 720 from 1080p.
-Used a different preset (superfast, ultrafast).
-Tried a different FMS URL.
-Swapped to a different streaming website (own3d.tv).
-Changed the fps (20,24,25,30).
-Changed the send buffer to different amounts.
-Unparked my cores.
Here is the video of the log below: http://www.twitch.tv/tmatsou/b/358921576
The video to the log below: http://www.twitch.tv/tmatsou/b/358925320
Shaperprobe result:
Speedtest.net & Pingtest result:
-Unparked my cores.
Open Broadcaster Software v0.466a - 32bit (´・ω・`)
CPU Name: Intel(R) Core(TM) i5-2500K CPU @ 3.30GHz
CPU Speed: 3309MHz
Physical Memory: 4095MB Total, 4095MB Free
stepping id: 7, model 10, family 6, type 0, extmodel 1, extfamily 0, HTT 1, logical cores 4, total cores 4
Aero is Disabled
Adapter 1
Video Adapter: NVIDIA GeForce GTX 460
Video Adapter Dedicated Video Memory: 1025966080
Video Adapter Shared System Memory: 3221106688
Base resolution: 1920x1080
Output resolution: 1920x1080
Loading up D3D10...
Using auxilary audio input: Microphone (Turtle Beach P11 Headset)
Audio Encoding: AAC
bitrate: 320
Using graphics capture
Warning -- DShowPlugin: Invalid device: name 'Logitech HD Webcam C270', path '\\?\usb#vid_046d&pid_0825&mi_00#7&364e394f&0&0000#{65e8773d-8f56-11d0-a3b9-00a0c9223196}\{bbefb6c7-2fc4-4139-bb8b-a58bba724083}'
Warning -- D3D10Texture::CreateTexture: CreateTexture2D failed, result = 0x80070057
Using directshow input
Using text output
Using custom x264 settings: "vbvmaxrate=5000"
Video Encoding: x264
fps: 60
width: 1920, height: 1080
preset: veryfast
CBR: no
max bitrate: 4000
buffer size: 1000
quality: 7
SharedTexCapture hooked
Total frames rendered: 179, number of frames that lagged: 102 (56.98%) (it's okay for some frames to lag)
Server selection: rtmp://live-iad-backup.justin.tv/app
RTMPPublisher::SocketLoop: Aborting due to loop exit
Loading up D3D10...
Audio Encoding: AAC
bitrate: 320
Using text output
fps: 30
preset: veryfast
CBR: no
max bitrate: 4000
buffer size: 1000
quality: 7
bufferTime: 1458, outputRateWindowTime: 1000, dropThreshold: 1958
Total frames rendered: 43053, number of frames that lagged: 1151 (2.67%) (it's okay for some frames to lag)
Profiler results:
frame - [100%] [avg time: 16.457 ms] [avg calls per frame: 1] [children: 99%] [unaccounted: 1.01%]
| scene->Preprocess - [1.01%] [avg time: 0.167 ms] [avg calls per frame: 1]
| video encoding and uploading - [98%] [avg time: 16.123 ms] [avg calls per frame: 1] [children: 19.3%] [unaccounted: 78.7%]
| | CopyResource - [0.0729%] [avg time: 0.012 ms] [avg calls per frame: 0]
| | conversion to 4:2:0 - [0.28%] [avg time: 0.046 ms] [avg calls per frame: 0]
| | call to encoder - [18.6%] [avg time: 3.062 ms] [avg calls per frame: 0]
| | sending stuff out - [0.292%] [avg time: 0.048 ms] [avg calls per frame: 0]
CPU Speed: 3309MHz
Aero is Disabled
Adapter 1
Loading up D3D10...
Audio Encoding: AAC
bitrate: 320
Using text output
fps: 60
preset: veryfast
CBR: no
max bitrate: 4000
buffer size: 1000
quality: 7
Loading up D3D10...
Audio Encoding: AAC
bitrate: 320
Using text output
fps: 30
preset: veryfast
CBR: no
max bitrate: 4000
buffer size: 1000
quality: 7
Profiler results:
CPU Speed: 3309MHz
Aero is Disabled
Adapter 1
Loading up D3D10...
Audio Encoding: AAC
bitrate: 320
Using text output
fps: 30
preset: veryfast
CBR: no
max bitrate: 4000
buffer size: 4000
quality: 7
bufferTime: 1743, outputRateWindowTime: 1000, dropThreshold: 2243
Total frames rendered: 7929, number of frames that lagged: 669 (8.44%) (it's okay for some frames to lag)
Profiler results:
frame - [100%] [avg time: 20.759 ms] [avg calls per frame: 1] [children: 98.9%] [unaccounted: 1.06%]
| scene->Preprocess - [0.829%] [avg time: 0.172 ms] [avg calls per frame: 1]
| video encoding and uploading - [98.1%] [avg time: 20.366 ms] [avg calls per frame: 1] [children: 16.9%] [unaccounted: 81.2%]
| | CopyResource - [0.0578%] [avg time: 0.012 ms] [avg calls per frame: 0]
| | conversion to 4:2:0 - [0.159%] [avg time: 0.033 ms] [avg calls per frame: 0]
| | call to encoder - [16.5%] [avg time: 3.429 ms] [avg calls per frame: 0]
| | sending stuff out - [0.198%] [avg time: 0.041 ms] [avg calls per frame: 0]
CPU Speed: 3309MHz
Aero is Disabled
Adapter 1
Loading up D3D10...
Audio Encoding: AAC
bitrate: 320
Using text output
fps: 30
preset: veryfast
CBR: no
max bitrate: 4000
buffer size: 4000
quality: 7
Profiler results:
Shaperprobe result:
DiffProbe release. January 2012. Build 1008.
Shaper Detection Module.
Connected to server 80.239.142.215.
Estimating capacity:
Upstream: 10718 Kbps.
Downstream: 83225 Kbps.
The measurement will take upto 2.5 minutes. Please wait.
Checking for traffic shapers:
Upstream: No shaper detected.
Median received rate: 10490 Kbps.
Downstream: Burst size: 6147-7376 KB;
Shaping rate: 53013 Kbps.
For more information, visit: http://www.cc.gatech.edu/~partha/diffprobe
