Question / Help Frame Drops and lag
Vinny Zhao
Using OBS on windows partition on my mac
I have done tons of trial and error and have used suggested settings found on youtube, but still cant seem to get a smooth stream without fps drops or lag occasionally. Is it my settings, internet or is my macbook simply not powerful enough to handle streaming?
Stream Service
Mixer
Mac Specs
mid 2014 15in with retina
i7 2.2ghz
16gb RAM
Xbox one x -----> Elgato HD60
OBS 21.0.1
LOG FILE
https://gist.github.com/58023c70192dc21be018bc74f5926b51
Hard wired connection through Ethernet
  • 100 up average, 35 down average
OBS Settings
i think my settings are at pretty low as is, but still experiencing frame drops and lag
  • rescale output 852x480, balaned, main, keyframe 2, async 4, CBR, bitrate 2500
  • output resolution 852x480, bicubic, fps 30
I would try lower bitrate to 1500
My Mac specs:
MBP 13, 2.4 i5, 8G ram
Blackmagic Web Presenter
Most of the time 0 drop frappes, Audio sync is very close.
Narcogen
You'd probably get better support for a question about OBS on Windows in the Windows support forum.
That said...
22:51:01.198: Output 'adv_stream': Number of lagged frames due to rendering lag/stalls: 531 (5.8%)
