Hello, today i have been having alooooot of problems with OBS.
Whenever i start up the stream it goes ok for like 30 seconds, after 30 secs the frame drop goes up to 100% and this ends up in the stream more or less just crash.
If i try to restart the stream the same thing happens again after a while.
I have never had this problem before and it just started today.
PC Speccs
Intel Core i5 2500K @ 3.30ghz
8,00 GB Ram
1024MB GeForce GTX 560 Ti
(Against Frankfurt since that seems to be the closest server to stream against, i'm swedish)
OBS Settings
Quality Balance 8
Max Bitrate/Buffer size 5500
Base Resolution @ 1680*1050 Downscaled 2.00
And nothing changed in the advance tab
Anyone know what the problem might be?
PC Speccs
8,00 GB Ram
OBS Settings
Quality Balance 8
