Open Broadcaster Software v0.472b - 64bit ( ^ω^)
CPU Name: AMD Phenom(tm) II X4 955 Processor
CPU Speed: 3200MHz
Physical Memory: 8191MB Total, 5449MB Free
stepping id: 3, model 4, family 15, type 0, extmodel 8, extfamily 0, HTT 1, logical cores 4, total cores 4
monitor 1: pos={0, 0}, size={1600, 900}
monitor 2: pos={-1360, -100}, size={1360, 768}
Windows Version: 6.1 Build 7600
Aero is Enabled
Adapter 1
Video Adapter: NVIDIA GeForce GTX 560 Ti
Video Adapter Dedicated Video Memory: 1025966080
Video Adapter Shared System Memory: 3221106688
Base resolution: 1600x900
Output resolution: 1064x600
Loading up D3D10...
Playback device {0.0.0.00000000}.{dd5fea43-3c61-4ddb-a05a-ad2786d4cfdb}
Using desktop audio input: Speakers (Realtek High Definition Audio)
Using auxilary audio input: Mic in at rear panel (Pink) (Realtek High Definition Audio)
Audio Encoding: AAC
bitrate: 128
Using graphics capture
Using Monitor Capture
x264: using cpu capabilities: MMX2 SSE2Fast FastShuffle SSEMisalign LZCNT
x264: profile High, level 3.1
Video Encoding: x264
fps: 25
width: 1064, height: 600
preset: veryfast
CBR: no
CFR: no
max bitrate: 1000
buffer size: 1000
quality: 8
Total frames rendered: 12835, number of frames that lagged: 3756 (29.26%) (it's okay for some frames to lag)
x264: frame I:54 Avg QP:20.75 size: 84363
x264: frame P:3332 Avg QP:20.23 size: 972
x264: frame B:9413 Avg QP:22.08 size: 71
x264: consecutive B-frames: 1.8% 0.3% 0.7% 97.3%
x264: mb I I16..4: 32.8% 11.7% 55.4%
x264: mb P I16..4: 0.5% 0.3% 0.2% P16..4: 1.8% 0.5% 0.3% 0.0% 0.0% skip:96.4%
x264: mb B I16..4: 0.0% 0.0% 0.0% B16..8: 0.1% 0.0% 0.0% direct: 0.1% skip:99.7% L0:41.0% L1:47.6% BI:11.4%
x264: 8x8 transform intra:18.4% inter:28.5%
x264: coded y,uvDC,uvAC intra: 60.0% 54.3% 39.8% inter: 0.3% 0.3% 0.1%
x264: i16 v,h,dc,p: 47% 45% 5% 4%
x264: i8 v,h,dc,ddl,ddr,vr,hd,vl,hu: 13% 43% 19% 3% 4% 3% 5% 3% 7%
x264: i4 v,h,dc,ddl,ddr,vr,hd,vl,hu: 22% 33% 13% 3% 7% 5% 5% 4% 8%
x264: i8c dc,h,v,p: 46% 33% 16% 5%
x264: Weighted P-Frames: Y:0.2% UV:0.2%
x264: kb/s:123.02
Profiler results:
frame - [100%] [avg time: 35.846 ms] [avg calls per frame: 1] [children: 98.5%] [unaccounted: 1.5%]
| scene->Preprocess - [93%] [avg time: 33.324 ms] [avg calls per frame: 1]
| video encoding and uploading - [5.54%] [avg time: 1.986 ms] [avg calls per frame: 1] [children: 3.96%] [unaccounted: 1.58%]
| | CopyResource - [0.067%] [avg time: 0.024 ms] [avg calls per frame: 0]
| | conversion to 4:2:0 - [0.0167%] [avg time: 0.006 ms] [avg calls per frame: 0]
| | call to encoder - [3.87%] [avg time: 1.386 ms] [avg calls per frame: 0]
| | sending stuff out - [0.00558%] [avg time: 0.002 ms] [avg calls per frame: 0]
