Question / Help FPS recently got low/freezy (recording)
raphoyz
Hi. Recently my recordings begun to get very low FPS, sometimes even freezing and I have no idea why. My GPU drivers are updated and also is my OBS. I've tried a lot but nothing works. Also, I don't know if this matters at all but I've also changed the OBS from C: to D: since I don't have much space on the C:(SSD) but I don't actually remember if that's when the FPS started getting low. Another issue that I'm having is that I can't use NVENC encoder, cause my OBS crashes when I try to record using it (print screen attached). I'd be really glad if you guys would help me with that. Thanks!!
My specs:
CPU: Intel i5 7600
GPU: GTX 1050ti 4GB
RAM: 16GB
MB: Gigabyte B250M-GAMING 3
  • OBS Logs.zip
  • Crash 2018-06-23 23-41-55.txt
