Question / Help FPS drops
t1tans
Hi! I want to stream some CS 1.6 and i have problems with fps drops, when i stream lol on full details with 720p quality the game works better than cs on lower quality! It looks like i got 100fps but it drop down to 60~ every 3~ sec. I tried many configurations but it didnt help. I dont know what to do!
pen Broadcaster Software v0.47a - 32bit (´・ω・`)
CPU Name: AMD Phenom(tm) II X4 20 Processor
CPU Speed: 2793MHz
Physical Memory:  4095MB Total, 2224MB Free
stepping id: 2, model 4, family 15, type 0, extmodel 8, extfamily 0, HTT 1, logical cores 4, total cores 4
Windows Version: 6.1 Build 7600
Aero is Disabled
Adapter 1
  Video Adapter: NVIDIA GeForce GTX 260
  Video Adapter Dedicated Video Memory: 919994368
  Video Adapter Shared System Memory: 1878683648
  Base resolution: 800x600
  Output resolution: 800x600
Loading up D3D10...
Playback device Default
Using desktop audio input: Cyfrowy interfejs audio (SB Audigy)
Using auxilary audio input: Microphone (SB Audigy)
Audio Encoding: AAC
    bitrate: 128
Using Window Capture
Using Monitor Capture
Using graphics capture
Video Encoding: x264
    fps: 25
    width: 800, height: 600
    preset: superfast
    CBR: no
    CFR: no
    max bitrate: 1500
    buffer size: 1500
    quality: 10
Using fixed low latency mode, factor 20
  Server selection: rtmp://live-fra.justin.tv/app
bufferTime: 2119, outputRateWindowTime: 1000, dropThreshold: 2619
using memory capture
Krazy
Town drunk
There's no need for all three of those sources in one scene. Pick one to use and delete the others.
hilalpro
that's not the complete log file.. after doing a streaming test run close obs go to %AppData%\OBS\logs and copy past the whole txt file with latest modified time on here.
t1tans
Here you go:
Open Broadcaster Software v0.47a - 32bit (´・ω・`)
CPU Speed: 2793MHz
Physical Memory:  4095MB Total, 2001MB Free
Aero is Disabled
Adapter 1
Loading up D3D10...
Audio Encoding: AAC
    bitrate: 128
    fps: 25
    preset: superfast
    CBR: no
    CFR: no
    max bitrate: 1500
    buffer size: 1500
    quality: 10
Total frames rendered: 21, number of frames that lagged: 0 (0.00%) (it's okay for some frames to lag)
Loading up D3D10...
Audio Encoding: AAC
    bitrate: 128
    fps: 25
    preset: superfast
    CBR: no
    CFR: no
    max bitrate: 1500
    buffer size: 1500
    quality: 10
bufferTime: 2133, outputRateWindowTime: 1000, dropThreshold: 2633
hilalpro
use the latest test version on the right from the downoad page and post a log. uncheck the sources that you're not using.
also put the game process on " high priority" from task manager.
