I want to stream League of Legends, but my fps drops to +- 40, but it feels like I'm playing at 10 fps. I'm using Windows 8 64 Bit
Here is the log :
Thanks
Here is the log :
Open Broadcaster Software v0.452a - 32bit (´・ω・`)
CPU Name: Intel(R) Core(TM)2 Quad CPU Q9650 @ 3.00GHz
CPU Speed: 3000MHz
Physical Memory: 4095MB Total, 4095MB Free
stepping id: 10, model 7, family 6, type 0, extmodel 0, extfamily 0, HTT 1, logical cores 4, total cores 4
Adapter 1
Video Adapter: AMD Radeon HD 6800 Series
Video Adapter Dedicated Video Memory: 1057464320
Video Adapter Shared System Memory: 3237437440
Adapter 2
Video Adapter: Microsoft Basic Render Driver
Video Adapter Dedicated Video Memory: 0
Video Adapter Shared System Memory: 268435456
Base resolution: 1920x1080
Output resolution: 1920x1080
Loading up D3D10...
Using auxilary audio input: Microfoon (Microsoft LifeCam VX-5000)
Audio Encoding: AAC
bitrate: 128
Video Encoding: x264
fps: 30
width: 1920, height: 1080
preset: veryfast
CBR: no
max bitrate: 1000
buffer size: 1000
quality: 8
Total frames rendered: 58, number of frames that lagged: 0 (0.00%) (it's okay for some frames to lag)
Loading up D3D10...
Audio Encoding: AAC
bitrate: 128
fps: 30
preset: veryfast
CBR: no
max bitrate: 1000
buffer size: 1000
quality: 8
Total frames rendered: 202, number of frames that lagged: 0 (0.00%) (it's okay for some frames to lag)
Loading up D3D10...
Audio Encoding: AAC
bitrate: 128
fps: 30
preset: veryfast
CBR: no
max bitrate: 1000
buffer size: 1000
quality: 8
Total frames rendered: 2849, number of frames that lagged: 2 (0.07%) (it's okay for some frames to lag)
Loading up D3D10...
Audio Encoding: AAC
bitrate: 128
fps: 30
preset: veryfast
CBR: no
max bitrate: 1000
buffer size: 1000
quality: 8
SO_SNDBUF already at 65536
bufferTime: 2002, outputRateWindowTime: 1000, dropThreshold: 2502
Total frames rendered: 184, number of frames that lagged: 0 (0.00%) (it's okay for some frames to lag)
Loading up D3D10...
Audio Encoding: AAC
bitrate: 128
fps: 30
preset: veryfast
CBR: no
max bitrate: 1000
buffer size: 1000
quality: 8
Total frames rendered: 163, number of frames that lagged: 0 (0.00%) (it's okay for some frames to lag)
Loading up D3D10...
Audio Encoding: AAC
bitrate: 128
fps: 30
preset: veryfast
CBR: no
max bitrate: 1000
buffer size: 1000
quality: 8
bufferTime: 2000, outputRateWindowTime: 1000, dropThreshold: 2500
using shared texture capture
Total frames rendered: 19496, number of frames that lagged: 791 (4.06%) (it's okay for some frames to lag)
Loading up D3D10...
Audio Encoding: AAC
bitrate: 128
fps: 30
preset: veryfast
CBR: no
max bitrate: 1000
buffer size: 1000
quality: 8
bufferTime: 2123, outputRateWindowTime: 1000, dropThreshold: 2623
Total frames rendered: 55180, number of frames that lagged: 6879 (12.47%) (it's okay for some frames to lag)
Number of b-frames dropped: 153 (0.11%), Number of p-frames dropped: 158 (0.11%), Total 311 (0.22%)
Loading up D3D10...
Audio Encoding: AAC
bitrate: 128
fps: 30
preset: veryfast
CBR: no
max bitrate: 2600
buffer size: 2800
quality: 8
bufferTime: 2001, outputRateWindowTime: 1000, dropThreshold: 2501
Total frames rendered: 82181, number of frames that lagged: 17269 (21.01%) (it's okay for some frames to lag)
Number of b-frames dropped: 3655 (1.5%), Number of p-frames dropped: 3238 (1.3%), Total 6893 (2.8%)
