here is the log from game capture:
00:30:13: Open Broadcaster Software v0.522b - 32bit (´・ω・`)
00:30:13: -------------------------------
00:30:13: CPU Name: Intel(R) Core(TM) i5-3570 CPU @ 3.40GHz
00:30:13: CPU Speed: 3392MHz
00:30:13: Physical Memory: 3561MB Total, 2074MB Free
00:30:13: stepping id: 9, model 10, family 6, type 0, extmodel 1, extfamily 0, HTT 1, logical cores 4, total cores 4
00:30:13: monitor 1: pos={0, 0}, size={1680, 1050}
00:30:13: Windows Version: 6.1 Build 7601 S
00:30:13: Aero is Disabled
00:30:13: OBS Modules:
00:30:13: Base Address Module
00:30:13: 01210000 OBS.exe
00:30:13: 57910000 OBSApi.dll
00:30:13: 71360000 DShowPlugin.dll
00:30:13: 71340000 GraphicsCapture.dll
00:30:13: 71320000 NoiseGate.dll
00:30:13: ------------------------------------------
00:30:13: Adapter 1
00:30:13: Video Adapter: ATI Radeon HD 5700 Series
00:30:13: Video Adapter Dedicated Video Memory: 1064448000
00:30:13: Video Adapter Shared System Memory: 1598611456
00:30:13: =====Stream Start: 2013-07-06, 00:30:13===============================================
00:30:13: Multithreaded optimizations: On
00:30:13: Base resolution: 1680x1050
00:30:13: Output resolution: 1680x1050
00:30:13: Loading up D3D10...
00:30:13: Playback device Default
00:30:13: Using desktop audio input: Ηχεία (VIA High Definition Audio)
00:30:13: Audio Encoding: AAC
00:30:13: bitrate: 128
00:30:13: Using graphics capture
00:30:13: Video Encoding: x264
00:30:13: fps: 30
00:30:13: width: 1680, height: 1050
00:30:13: preset: veryfast
00:30:13: CBR: yes
00:30:13: CFR: no
00:30:13: max bitrate: 725
00:30:14: SharedTexCapture hooked
00:30:15: Using RTMP service: Twitch / Justin.tv
00:30:15: Server selection:
rtmp://live-lhr-backup.justin.tv/app
00:30:17: SO_SNDBUF was at 8192
00:30:17: SO_SNDBUF is now 65536
00:30:31: Exit signal received, terminating capture
00:30:33: Total frames rendered: 570, number of frames that lagged: 1 (0.18%) (it's okay for some frames to lag)
00:30:33: RTMPPublisher::SocketLoop: Aborting due to bStopping
00:30:33: Number of times waited to send: 0, Waited for a total of 0 bytes
00:30:33: Number of b-frames dropped: 0 (0%), Number of p-frames dropped: 0 (0%), Total 0 (0%)
00:30:33: =====Stream End: 2013-07-06, 00:30:33=================================================
00:30:50:
00:30:50: Profiler results:
00:30:50:
00:30:50: ==============================================================
00:30:50: frame - [100%] [avg time: 2.659 ms] [avg calls per frame: 1] [children: 71.7%] [unaccounted: 28.3%]
00:30:50: | scene->Preprocess - [0%] [avg time: 0 ms] [avg calls per frame: 1]
00:30:50: | video encoding and uploading - [71.7%] [avg time: 1.907 ms] [avg calls per frame: 1] [children: 70.4%] [unaccounted: 1.32%]
00:30:50: | | CopyResource - [0.226%] [avg time: 0.006 ms] [avg calls per frame: 0]
00:30:50: | | conversion to 4:2:0 - [0.0752%] [avg time: 0.002 ms] [avg calls per frame: 0]
00:30:50: | | call to encoder - [69.5%] [avg time: 1.849 ms] [avg calls per frame: 0]
00:30:50: | | sending stuff out - [0.564%] [avg time: 0.015 ms] [avg calls per frame: 0]
00:30:50:
(I just copy pasted it,I didn't understand what pastebin does or what is the "code button referred in your linked guide. :P)
Thanks for trying to help! :D
