Question / Help Fixing pixelated and improve quality
TonyB
My stream has pixelation and I don't know how to solve it.
In addition, I would like to ask you if I can improve my quality stream.
My network speed is 300/300, connected by ethernet.
My specs of pc:
Windows 10 64 bits
Phenom ii x4 955 processor,
8 gb ram
Amd radeon r 7200
Log:
http://pastebin.com/5iY1MSTA
Best regards,
  • 2016-10-20-2137-25.log
alpinlol
your CPU is to weak to stream anyway but to fix the pixelation while movement you would have to use the veryfast Preset and you should be fine with a 2000 Bitrate
