Failed To Open NVENC Codec - Worked fine in 27.1.3 and below.
SaulBB
Title pretty much says it, I've been using OBS for over a year now and have always used "NVIDIA NVENC H.264 (new)" Encoder, and whenever I've updated to any of the recent updates (27.2+) I always get the error "Failed To Open NVENC Codec" when attempting to record. I've had to down grade in order to keep using the software. Am I doing something wrong or is this a known issue? Any help would be appreciated.
I wasn't sure which log file is the correct one so I've attached all from the first day I encountered this issue.
  • 2022-02-22 11-06-14.txt
  • 2022-02-22 11-10-01.txt
  • 2022-02-22 11-11-18.txt
  • 2022-02-22 11-12-07.txt
  • 2022-02-22 11-12-48.txt
cyclemat
have you updated you display drivers ?
tip from me
11:12:07.698: McAfee Firewall: disabled (FW)
11:12:07.697: McAfee VirusScan: disabled (AV)
deinstall the shit
update obs to 27.2.3
SaulBB
Yeah, that has fixed it, Thank you.
I had tried updating them though windows before, but straight from NVIDIA did it.
