Shelledfade
http://www.twitch.tv/shelledfade/c/2561673
As you can see in this video it's stuttering extremely bad. I didn't have this problem until I installed latest update for OBS software, changed no settings on my end and the stream is practically unwatchable because of this stuttering problem. While in-games I notice no problems at all.
I even tried to lower the quality of the stream but its still extremely Jittery. I did not have this problem until OBS updated recently, then this started happening. Don't know what I can do/change to make it go away because like I said before, I did not have this issue at all until obs updated recently.
12:50:49: Open Broadcaster Software v0.522b - 32bit (´・ω・`)
12:50:49: -------------------------------
12:50:49: CPU Name: Intel(R) Core(TM) i7-2600K CPU @ 3.40GHz
12:50:49: CPU Speed: 3400MHz
12:50:49: Physical Memory: 4095MB Total, 4095MB Free
12:50:49: stepping id: 7, model 10, family 6, type 0, extmodel 1, extfamily 0, HTT 1, logical cores 8, total cores 4
12:50:49: monitor 1: pos={0, 0}, size={1920, 1080}
12:50:49: Windows Version: 6.1 Build 7601 S
12:50:49: Aero is Enabled
12:50:49: OBS Modules:
12:50:49: Base Address Module
12:50:49: 013A0000 OBS.exe
12:50:49: 68F20000 OBSApi.dll
12:50:49: 68C90000 DShowPlugin.dll
12:50:49: 68C70000 GraphicsCapture.dll
12:50:49: 68C50000 NoiseGate.dll
12:50:49: ------------------------------------------
12:50:49: Adapter 1
12:50:49: Video Adapter: ATI Radeon HD 5900 Series
12:50:49: Video Adapter Dedicated Video Memory: 2118795264
12:50:49: Video Adapter Shared System Memory: 2176106496
12:50:49: =====Stream Start: 2013-07-08, 12:50:49===============================================
12:50:49: Multithreaded optimizations: On
12:50:49: Base resolution: 1920x1080
12:50:49: Output resolution: 1920x1080
12:50:49: Loading up D3D10...
12:50:49: Playback device {0.0.0.00000000}.{5d6e1fc7-8c2e-4ca0-8dfe-b17168459c99}
12:50:49: Using desktop audio input: Speakers (Logitech G35 Headset)
12:50:49: Using 7.1 surround speaker setup
12:50:49: Using auxilary audio input: Microphone (Logitech G35 Headset)
12:50:49: Audio Encoding: AAC
12:50:49: bitrate: 128
12:50:49: Using Monitor Capture
12:50:49: Using graphics capture
12:50:49: Video Encoding: x264
12:50:49: fps: 30
12:50:49: width: 1920, height: 1080
12:50:49: preset: veryfast
12:50:49: CBR: yes
12:50:49: CFR: no
12:50:49: max bitrate: 2500
12:50:50: SharedTexCapture hooked
12:50:51: Using RTMP service: Twitch / Justin.tv
12:50:51: Server selection: rtmp://live-iad.justin.tv/app
12:50:52: SO_SNDBUF was at 8192
12:50:52: SO_SNDBUF is now 65536
12:51:09: Capture window 0x003E0332 invalid or changing, terminating capture
12:51:14: SharedTexCapture hooked
12:51:42: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
12:51:42: New Scene
12:51:43: Using bitmap image
12:52:23: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
12:52:23: New Scene
12:52:23: Using Monitor Capture
12:52:23: Using graphics capture
12:52:23: SharedTexCapture hooked
12:52:45: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
12:52:45: New Scene
12:52:45: Using bitmap image
12:53:02: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
12:53:02: New Scene
12:53:02: Using Monitor Capture
12:53:02: Using graphics capture
12:53:02: SharedTexCapture hooked
12:53:36: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
12:53:36: New Scene
12:53:36: Using bitmap image
12:53:39: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
12:53:39: New Scene
12:53:39: Using Monitor Capture
12:53:39: Using graphics capture
12:53:39: SharedTexCapture hooked
13:01:19: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
13:01:19: New Scene
13:01:19: Using bitmap image
13:01:32: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
13:01:32: New Scene
13:01:32: Using Monitor Capture
13:01:32: Using graphics capture
13:01:32: SharedTexCapture hooked
13:02:06: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
13:02:06: New Scene
13:02:06: Using bitmap image
13:02:09: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
13:02:09: New Scene
13:02:09: Using Monitor Capture
13:02:09: Using graphics capture
13:02:09: SharedTexCapture hooked
13:09:25: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
13:09:25: New Scene
13:09:25: Using bitmap image
13:09:28: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
13:09:28: New Scene
13:09:28: Using Monitor Capture
13:09:28: Using graphics capture
13:09:28: SharedTexCapture hooked
13:10:06: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
13:10:06: New Scene
13:10:07: Using bitmap image
13:10:15: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
13:10:15: New Scene
13:10:15: Using Monitor Capture
13:10:15: Using graphics capture
13:10:15: SharedTexCapture hooked
13:10:54: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
13:10:54: New Scene
13:10:54: Using bitmap image
13:10:57: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
13:10:57: New Scene
13:10:57: Using Monitor Capture
13:10:57: Using graphics capture
13:10:58: SharedTexCapture hooked
13:18:27: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
13:18:27: New Scene
13:18:27: Using bitmap image
13:18:40: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
13:18:40: New Scene
13:18:40: Using Monitor Capture
13:18:40: Using graphics capture
13:18:40: SharedTexCapture hooked
13:19:14: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
13:19:14: New Scene
13:19:14: Using bitmap image
13:19:15: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
13:19:15: New Scene
13:19:15: Using Monitor Capture
13:19:15: Using graphics capture
13:19:15: SharedTexCapture hooked
13:23:31: Capture window 0x001C02F4 invalid or changing, terminating capture
13:23:42: SharedTexCapture hooked
13:23:49: Capture window 0x00030492 invalid or changing, terminating capture
13:23:53: SharedTexCapture hooked
13:24:04: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
13:24:04: New Scene
13:24:04: Using bitmap image
13:24:19: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
13:24:19: New Scene
13:24:19: Using Monitor Capture
13:24:19: Using graphics capture
13:24:19: SharedTexCapture hooked
13:26:48: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
13:26:48: New Scene
13:26:48: Using bitmap image
13:26:56: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
13:26:56: New Scene
13:26:56: Using Monitor Capture
13:26:56: Using graphics capture
13:26:56: SharedTexCapture hooked
13:28:09: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
13:28:09: New Scene
13:28:09: Using bitmap image
13:28:14: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
13:28:14: New Scene
13:28:14: Using Monitor Capture
13:28:14: Using graphics capture
13:28:14: SharedTexCapture hooked
13:28:56: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
13:28:56: New Scene
13:28:56: Using bitmap image
13:28:59: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
13:28:59: New Scene
13:28:59: Using Monitor Capture
13:28:59: Using graphics capture
13:28:59: SharedTexCapture hooked
13:30:44: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
13:30:44: New Scene
13:30:44: Using bitmap image
13:30:46: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
13:30:46: New Scene
13:30:46: Using Monitor Capture
13:30:46: Using graphics capture
13:30:46: SharedTexCapture hooked
13:31:47: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
13:31:47: New Scene
13:31:48: Using bitmap image
13:31:50: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
13:31:50: New Scene
13:31:50: Using Monitor Capture
13:31:50: Using graphics capture
13:31:50: SharedTexCapture hooked
13:47:05: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
13:47:05: New Scene
13:47:05: Using bitmap image
13:47:19: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
13:47:19: New Scene
13:47:19: Using Monitor Capture
13:47:19: Using graphics capture
13:47:19: SharedTexCapture hooked
13:51:08: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
13:51:08: New Scene
13:51:08: Using bitmap image
13:51:42: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
13:51:42: New Scene
13:51:42: Using Monitor Capture
13:51:42: Using graphics capture
13:51:43: SharedTexCapture hooked
13:52:01: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
13:52:01: New Scene
13:52:01: Using bitmap image
13:52:02: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
13:52:02: New Scene
13:52:02: Using Monitor Capture
13:52:02: Using graphics capture
13:52:02: SharedTexCapture hooked
13:52:19: Capture window 0x001603AC invalid or changing, terminating capture
13:52:30: Total frames rendered: 84637, number of frames that lagged: 57551 (68.00%) (it's okay for some frames to lag)
13:52:30: RTMPPublisher::SocketLoop: Aborting due to bStopping
13:52:30: Number of times waited to send: 0, Waited for a total of 0 bytes
13:52:30: Number of b-frames dropped: 0 (0%), Number of p-frames dropped: 0 (0%), Total 0 (0%)
13:52:30: =====Stream End: 2013-07-08, 13:52:30=================================================
13:53:37: =====Stream Start: 2013-07-08, 13:53:37===============================================
13:53:37: Multithreaded optimizations: On
13:53:37: Base resolution: 1920x1080
13:53:37: Output resolution: 1920x1080
13:53:37: ------------------------------------------
13:53:37: Loading up D3D10...
13:53:37: Playback device {0.0.0.00000000}.{5d6e1fc7-8c2e-4ca0-8dfe-b17168459c99}
13:53:37: Using desktop audio input: Speakers (Logitech G35 Headset)
13:53:37: Using 7.1 surround speaker setup
13:53:37: Using auxilary audio input: Microphone (Logitech G35 Headset)
13:53:37: Audio Encoding: AAC
13:53:37: bitrate: 128
13:53:37: Using Monitor Capture
13:53:37: Using graphics capture
13:53:37: Video Encoding: x264
13:53:37: fps: 30
13:53:37: width: 1920, height: 1080
13:53:37: preset: veryfast
13:53:37: CBR: yes
13:53:37: CFR: no
13:53:37: max bitrate: 2500
13:53:37: SharedTexCapture hooked
13:53:39: Using RTMP service: Twitch / Justin.tv
13:53:39: Server selection: rtmp://live-iad.justin.tv/app
13:53:41: SO_SNDBUF was at 8192
13:53:41: SO_SNDBUF is now 65536
13:56:48: Capture window 0x00050486 invalid or changing, terminating capture
13:56:52: SharedTexCapture hooked
13:57:09: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
13:57:09: New Scene
13:57:09: Using bitmap image
13:57:42: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
13:57:42: New Scene
13:57:42: Using Monitor Capture
13:57:42: Using graphics capture
13:57:42: SharedTexCapture hooked
13:58:05: Capture window 0x000C0496 invalid or changing, terminating capture
13:58:15: SharedTexCapture hooked
13:58:19: Capture window 0x00060448 invalid or changing, terminating capture
13:58:23: SharedTexCapture hooked
13:58:37: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
13:58:37: New Scene
13:58:37: Using bitmap image
13:59:16: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
13:59:16: New Scene
13:59:17: Using Monitor Capture
13:59:17: Using graphics capture
13:59:17: SharedTexCapture hooked
14:00:18: Capture window 0x0008044A invalid or changing, terminating capture
14:01:02: SharedTexCapture hooked
14:01:08: Capture window 0x0008045C invalid or changing, terminating capture
14:01:12: SharedTexCapture hooked
14:01:24: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
14:01:24: New Scene
14:01:24: Using bitmap image
14:02:44: Total frames rendered: 15918, number of frames that lagged: 2527 (15.88%) (it's okay for some frames to lag)
14:02:44: RTMPPublisher::SocketLoop: Aborting due to bStopping
14:02:44: Number of times waited to send: 3, Waited for a total of 12291 bytes
14:02:44: Number of b-frames dropped: 135 (0.86%), Number of p-frames dropped: 134 (0.85%), Total 269 (1.7%)
14:02:44: =====Stream End: 2013-07-08, 14:02:44=================================================
14:02:46: =====Stream Start: 2013-07-08, 14:02:46===============================================
14:02:46: Multithreaded optimizations: On
14:02:46: Base resolution: 1920x1080
14:02:46: Output resolution: 1920x1080
14:02:46: ------------------------------------------
14:02:46: Loading up D3D10...
14:02:46: Playback device {0.0.0.00000000}.{5d6e1fc7-8c2e-4ca0-8dfe-b17168459c99}
14:02:46: Using desktop audio input: Speakers (Logitech G35 Headset)
14:02:46: Using 7.1 surround speaker setup
14:02:46: Using auxilary audio input: Microphone (Logitech G35 Headset)
14:02:46: Audio Encoding: AAC
14:02:46: bitrate: 128
14:02:46: Using bitmap image
14:02:46: Video Encoding: x264
14:02:46: fps: 30
14:02:46: width: 1920, height: 1080
14:02:46: preset: veryfast
14:02:46: CBR: yes
14:02:46: CFR: no
14:02:46: max bitrate: 2500
14:02:48: Using RTMP service: Twitch / Justin.tv
14:02:48: Server selection: rtmp://live-iad.justin.tv/app
14:02:50: SO_SNDBUF was at 8192
14:02:50: SO_SNDBUF is now 65536
14:03:26: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
14:03:26: New Scene
14:03:26: Using Monitor Capture
14:03:26: Using graphics capture
14:03:33: SharedTexCapture hooked
14:03:37: Capture window 0x000F0480 invalid or changing, terminating capture
14:03:41: SharedTexCapture hooked
14:03:57: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
14:03:57: New Scene
14:03:57: Using bitmap image
14:04:02: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
14:04:02: New Scene
14:04:02: Using Monitor Capture
14:04:02: Using graphics capture
14:04:02: SharedTexCapture hooked
14:04:27: Capture window 0x00110480 invalid or changing, terminating capture
14:04:52: Total frames rendered: 3502, number of frames that lagged: 1117 (31.90%) (it's okay for some frames to lag)
14:04:52: RTMPPublisher::SocketLoop: Aborting due to bStopping
14:04:52: Number of times waited to send: 0, Waited for a total of 0 bytes
14:04:52: Number of b-frames dropped: 0 (0%), Number of p-frames dropped: 0 (0%), Total 0 (0%)
14:04:52: =====Stream End: 2013-07-08, 14:04:52=================================================
14:04:55: =====Stream Start: 2013-07-08, 14:04:55===============================================
14:04:55: Multithreaded optimizations: On
14:04:55: Base resolution: 1920x1080
14:04:55: Output resolution: 1920x1080
14:04:55: ------------------------------------------
14:04:55: Loading up D3D10...
14:04:55: Playback device {0.0.0.00000000}.{5d6e1fc7-8c2e-4ca0-8dfe-b17168459c99}
14:04:55: Using desktop audio input: Speakers (Logitech G35 Headset)
14:04:55: Using 7.1 surround speaker setup
14:04:55: Using auxilary audio input: Microphone (Logitech G35 Headset)
14:04:55: Audio Encoding: AAC
14:04:55: bitrate: 128
14:04:55: Using Monitor Capture
14:04:55: Using graphics capture
14:04:55: Video Encoding: x264
14:04:55: fps: 30
14:04:55: width: 1920, height: 1080
14:04:55: preset: veryfast
14:04:55: CBR: yes
14:04:55: CFR: no
14:04:55: max bitrate: 2500
14:04:57: Using RTMP service: Twitch / Justin.tv
14:04:57: Server selection: rtmp://live-iad.justin.tv/app
14:04:57: librtmp error: rtmp://live-iad.justin.tv/app:
14:04:57: NetStream.Publish.Rejected (Authentication Failed.)
14:04:57: Connection to rtmp://live-iad.justin.tv/app failed: Could not access the specified channel or stream key. This could be because the key/channel is invalid, or because the server still thinks you are logged in.
14:04:57:
14:04:57: rtmp://live-iad.justin.tv/app:
14:04:57:
14:04:57: Total frames rendered: 76, number of frames that lagged: 12 (15.79%) (it's okay for some frames to lag)
14:04:57: Number of times waited to send: 0, Waited for a total of 0 bytes
14:04:57: Number of b-frames dropped: 0 (-1.$%), Number of p-frames dropped: 0 (-1.$%), Total 0 (-1.$%)
14:04:57: =====Stream End: 2013-07-08, 14:04:57=================================================
14:05:06: =====Stream Start: 2013-07-08, 14:05:06===============================================
14:05:06: Multithreaded optimizations: On
14:05:06: Base resolution: 1920x1080
14:05:06: Output resolution: 1920x1080
14:05:06: ------------------------------------------
14:05:06: Loading up D3D10...
14:05:06: Playback device {0.0.0.00000000}.{5d6e1fc7-8c2e-4ca0-8dfe-b17168459c99}
14:05:06: Using desktop audio input: Speakers (Logitech G35 Headset)
14:05:06: Using 7.1 surround speaker setup
14:05:06: Using auxilary audio input: Microphone (Logitech G35 Headset)
14:05:06: Audio Encoding: AAC
14:05:06: bitrate: 128
14:05:06: Using Monitor Capture
14:05:06: Using graphics capture
14:05:06: Video Encoding: x264
14:05:06: fps: 30
14:05:06: width: 1920, height: 1080
14:05:06: preset: veryfast
14:05:06: CBR: yes
14:05:06: CFR: no
14:05:06: max bitrate: 2500
14:05:08: Using RTMP service: Twitch / Justin.tv
14:05:08: Server selection: rtmp://live-iad.justin.tv/app
14:05:10: SO_SNDBUF was at 8192
14:05:10: SO_SNDBUF is now 65536
14:07:02: RTMPPublisher::BufferedSend: Increasing socket send buffer to ISB 131072
14:07:06: RTMPPublisher::BufferedSend: Increasing socket send buffer to ISB 262144
14:08:21: Total frames rendered: 5595, number of frames that lagged: 1357 (24.25%) (it's okay for some frames to lag)
14:08:21: RTMPPublisher::SocketLoop: Aborting due to bStopping
14:08:21: Number of times waited to send: 40, Waited for a total of 152252 bytes
14:08:21: Number of b-frames dropped: 239 (4.4%), Number of p-frames dropped: 220 (4%), Total 459 (8.4%)
14:08:21: =====Stream End: 2013-07-08, 14:08:21=================================================
14:08:28:
14:08:28: Profiler results:
14:08:28:
14:08:28: ==============================================================
14:08:28: frame - [100%] [avg time: 36.757 ms] [avg calls per frame: 1] [children: 99.9%] [unaccounted: 0.125%]
14:08:28: | scene->Preprocess - [93.7%] [avg time: 34.45 ms] [avg calls per frame: 1]
14:08:28: | video encoding and uploading - [6.15%] [avg time: 2.261 ms] [avg calls per frame: 1] [children: 6.04%] [unaccounted: 0.114%]
14:08:28: | | CopyResource - [0.0354%] [avg time: 0.013 ms] [avg calls per frame: 0]
14:08:28: | | conversion to 4:2:0 - [0.00816%] [avg time: 0.003 ms] [avg calls per frame: 0]
14:08:28: | | call to encoder - [5.91%] [avg time: 2.173 ms] [avg calls per frame: 0]
14:08:28: | | sending stuff out - [0.0816%] [avg time: 0.03 ms] [avg calls per frame: 0]
14:08:28:
