Question / Help Extreme lag when trying to record screen for gaming.
Nick The Imac
Hey OBS.
I recently downloaded your program on my Macbook pro and my Imac. My macbook pro which has worse specs than my Imac seems to run the program while gaming with ease and just a little lag, but my Imac with way better specs and brand new lags so much that it is impossible to use.
My Imac contains:
iMac (27-inch, Late 2013)
3,4 GHz Intel Core i5
8 GB 1600 MHz DDR3
NVIDIA GeForce GTX 775M 2048 MB
I'm not sure that you can see anything in the log file, it just makes my computer react with 0,5 seconds delay... Causing mouse to be slow and everything to respond with a short delay making it hard to use..
My screen is: 2560x1440.
Logs say something else cause i just changed it to see if lag would be better... It wasn't
Can't upload the logs so im copying it in here.:
10:10:48.588: CPU Name: Intel(R) Core(TM) i5-4670 CPU @ 3.40GHz
10:10:48.588: CPU Speed: 3400MHz
10:10:48.588: Physical Cores: 4, Logical Cores: 4
10:10:48.588: Physical Memory: 8192MB Total
10:10:48.588: OS Name: Mac OS X (NSMACHOperatingSystem)
10:10:48.589: OS Version: Version 10.12.6 (Build 16G29)
10:10:48.589: Kernel Version: 16.7.0
10:10:48.694: hotkeys-cocoa: Using layout 'com.apple.keylayout.Danish'
10:10:48.711: Portable mode: false
10:10:49.283: OBS 20.0.1 (mac)
10:10:49.283: ---------------------------------
10:10:49.314: ---------------------------------
10:10:49.315: audio settings reset:
10:10:49.315: samples per sec: 44100
10:10:49.315: speakers: 2
10:10:49.432: ---------------------------------
10:10:49.432: Initializing OpenGL...
10:10:49.460: OpenGL version: 4.1 NVIDIA-10.17.5 355.10.05.45f01
10:10:49.885: ---------------------------------
10:10:49.885: video settings reset:
10:10:49.885: base resolution: 2560x1440
10:10:49.885: output resolution: 2560x1440
10:10:49.885: downscale filter: Bilinear
10:10:49.885: fps: 60/1
10:10:49.885: format: NV12
10:10:49.885: Audio monitoring device:
10:10:49.885: name: Standard
10:10:49.885: id: default
10:10:49.886: ---------------------------------
10:10:51.932: No blackmagic support
10:10:52.417: [VideoToolbox encoder]: Adding VideoToolbox H264 encoders
10:10:53.698: VLC found, VLC video source enabled
10:10:54.115: Failed to load 'en-US' text for module: 'obs-browser.so'
10:10:54.115: [browser_source: 'Version: 1.29.0']
10:10:54.115: ---------------------------------
10:10:54.115: Loaded Modules:
10:10:54.115: obs-browser.so
10:10:54.115: vlc-video.so
10:10:54.115: text-freetype2.so
10:10:54.115: rtmp-services.so
10:10:54.115: obs-x264.so
10:10:54.115: obs-vst.so
10:10:54.115: obs-transitions.so
10:10:54.115: obs-outputs.so
10:10:54.115: obs-filters.so
10:10:54.115: obs-ffmpeg.so
10:10:54.115: mac-vth264.so
10:10:54.115: mac-syphon.so
10:10:54.115: mac-decklink.so
10:10:54.115: mac-capture.so
10:10:54.115: mac-avcapture.so
10:10:54.115: linux-jack.so
10:10:54.115: image-source.so
10:10:54.115: frontend-tools.so
10:10:54.115: coreaudio-encoder.so
10:10:54.115: ==== Startup complete ===============================================
10:10:55.791: All scene data cleared
10:10:55.791: ------------------------------------------------
10:10:57.449: [Media Source 'Mediekilde']: settings:
10:10:57.449: input:
10:10:57.449: input_format: (null)
10:10:57.449: is_looping: no
10:10:57.449: is_hw_decoding: no
10:10:57.449: is_clear_on_media_end: yes
10:10:57.449: restart_on_activate: yes
10:10:57.449: close_when_inactive: no
10:10:57.452: Switched to scene 'Scene'
10:10:57.452: ------------------------------------------------
10:10:57.452: Loaded scenes:
10:10:57.452: - scene 'Scene':
10:10:57.452: - source: 'Mediekilde' (ffmpeg_source)
10:10:57.452: - source: 'VLC videokilde' (vlc_source)
10:11:50.175: User added source 'Skærm optag' (display_capture) to scene 'Scene'
10:12:08.126: User Removed source 'Skærm optag' (display_capture) from scene 'Scene'
10:14:09.946: ---------------------------------
10:14:09.968: video settings reset:
10:14:09.968: base resolution: 1280x720
10:14:09.968: output resolution: 1280x720
10:14:09.968: downscale filter: Bilinear
10:14:09.968: fps: 60/1
10:14:09.968: format: NV12
10:14:10.193: Settings changed (outputs, video)
10:14:10.193: ------------------------------------------------
10:14:15.674: User added source 'Skærm optag' (display_capture) to scene 'Scene'
10:14:25.079: User Removed source 'Skærm optag' (display_capture) from scene 'Scene'
10:23:52.015: User added source 'Skærm optag' (display_capture) to scene 'Scene'
10:24:41.688: User Removed source 'Skærm optag' (display_capture) from scene 'Scene'
  • 2017-08-25 10-10-48.txt
Narcogen
There's no stream attempt in the log which makes it difficult to diagnose.
Was your MBP also Retina?
