First off, let me just say thanks for making this amazing software. It makes streaming ever so smooth, with little to no FPS drop. Sadly though, I haven't been able to use it that much these past two weeks though, as I've had major problems with extreme frame drop/lag. I browse these forums often, and was sure to look for a solution before posting, but I couldn't find one, so here I am.
When streaming, my program has been having a tough time remaining connected to the twitch servers it seems, as my bitrate is often fluctuating to as little as 7kbps, all the way up to 2756kbps (which I didn't even know was possible, seeing as my max upload is 2mpbs), causing the fps counter at the bottom to dip down to levels where my stream is entirely unwatchable (1-3 at times!). Also, while all of this is happening, I'm constantly having to fight twitch, as I'll lose connection and my stream will restart. At times it's gotten so severe that it's consistently lost connection every 2-5 minutes.
It can't be my internet however, as I can easily hop onto xsplit and stream for multiple hours at a time with no problems (just bad ingame fps).
Below is a vod, and a log of that vod. Luckily I didn't lose connection in it, but the frame rate was still atrocious.
The vod: http://www.twitch.tv/hooliganmaster420/b/338359375
The log:
Note, these are only the settings I used for this stream in particular. I've tried lowering/raising both the bitrate and the max buffer, (Once I even had both set to a mere 100kpbs, and I still received lag/frame drops), changing my streaming fps (as low as 20, with no luck), changing the resolution I streamed in, changing twitch.tv servers, and changing the max buffer size (including turning it off), with no luck.
I really do like your program, so I hope to be able to use it in the future.
The log:
Send Buffer Size: 4096
Base resolution: 1920x1080
Output resolution: 1280x720
Loading up D3D10...
Using auxilary audio input: Microphone (3- Logitech USB Headset)
Audio Encoding: MP3
bitrate: 320
chosen type: RGB24, usingFourCC: false, res: 640x480 - 640x480, fps: 15-30, fourCC: 00000000
Video Encoding: x264
fps: 52
width: 1280, height: 720
quality: 8
preset: veryfast
i444: no
max bitrate: 1250
buffer size: 250
Total frames rendered: 6226, number of frames that lagged: 533 (8.56%) (it's okay for some frames to lag)
Number of b-frames dropped: 126, Number of p-frames dropped: 0
Profiler results:
frame - [100%] [avg time: 17.803 ms] [avg calls per frame: 1] [children: 98.3%] [unaccounted: 1.72%]
| scene->Preprocess - [88.5%] [avg time: 15.748 ms] [avg calls per frame: 1]
| video encoding and uploading - [9.82%] [avg time: 1.748 ms] [avg calls per frame: 1] [children: 9.54%] [unaccounted: 0.281%]
| | CopyResource - [0.0449%] [avg time: 0.008 ms] [avg calls per frame: 0]
| | conversion to 4:2:0 - [0.0169%] [avg time: 0.003 ms] [avg calls per frame: 0]
| | call to encoder - [9.48%] [avg time: 1.687 ms] [avg calls per frame: 0]
