Question / Help Error , help !
iMuuM
Hi !
I really want to stream but i have an error when i press previeuw stream.
it says : Could not create D3D10 device and swapping chain
This is a photo showing everything. Can someone plz help me ?
Thx
iMuuM
dodgepong
Administrator
Community Helper
Unfortunately, your GPU does not support certain features of DirectX 10 that OBS requires. A lot of integrated GPUs have this problem. You will need to get a discrete graphics card, or if you are using a laptop, you are sadly out of luck. Sorry :(
iMuuM
I planning to buy another pc..
Will it work then ? or do i need to buy a specific pc ? (not a laptop)
Helixia
If i'm not wrong she has an seperate graphic card of Nvidia.
So she needs to tell OBS that it needs to use her Nvidia card.
