Encoder Overload and High CPU Usage when using Butt with OBS Studio
signey
Hello! I recently started using Butt Encoder to stream audio at the same time I use OBS to stream into Facebook/Twitch, etc, using the Multiple Output and Advanced Scene Switcher plugins, but have been having issues with dropped frames and audio encoder issues. I looked at the CPU usage and notice that it hovers around 80%. I have no other apps open on my laptop. I also noticed that even without streaming. I could see a high count of Dropped Frames due to rendering lag, and fluctuating FPS. The Skipped Frames due to encoding lag counter was very low. The audio got so back that I had to restart OBS so I attached both logs. Thank you very much for any and all recommendations on settings to change or other adjustments.
  • 2020-09-02 18-41-35.txt
  • 2020-09-02 19-53-17.txt
