Elgato Marketplace Connect for OBS Studio
Elgato Marketplace Connect for OBS Studio 1.0.0
Elgato
Elgato submitted a new resource:
Elgato Marketplace Connect for OBS Studio - Add and share OBS setups in just a few clicks
SET UP EASIER​
Installing scenes and sources used to be a herculean task. Now, our wizard walks you through the process step by step, right inside OBS Studio. Once it’s done, everything is exactly as it should be, guaranteed.
GET GOING FASTER​
When entire scene collections load up in a flash, it feels amazing. With automated setup and zero troubleshooting, what once took hours now takes only minutes—so you can start streaming right away...
videorhetorik
Thank you very much, @FiniteSingularity ! This makes sharing OBS installations easier with the included maker tools.
Unfortunately, the “Audio Monitor” plugin seems to be overlooked by the Tool.
It is missing in my selection list of plugins “to be passed on”. So of course it is also missing in the list when importing into the second OBS.
However, the settings I made for an Audio Monitor filter were immediately present again as soon as I subsequently installed the Audio Monitor plugin.
Hi @videorhetorik,
I’m glad you’re enjoying the plugin. The behavior you’re seeing is as intended for this first version of the plugin. We were only able to test so many plugins before releasing, though we’ll be adding more plugins with each release. But as you’re noticing, it still saves the settings for Audio Monitor. It just won’t prompt you to Install it if missing.
felix13
Pregătit să intri în joc? Vizitează https://www.favbet.ro/ro/casino/ și lasă-te purtat de magia cazinoului Favbet! Cu mii de păcănele de top, precum Shining Crown, Gates of Olympus și Sweet Bonanza, plus mese live de ruletă, blackjack și baccarat, distracția e garantată. Profită de bonusuri suculente, rotiri gratuite și jackpoturi care îți pot schimba viața! Joacă direct de pe mobil sau PC, cu o platformă sigură, licențiată ONJN. Intră acum și prinde norocul!
