Bug Report Elgato HD60 Crashing when Previewing OBS
samysalti
Hi everyone,
I've seen through posts about the HD60 crashing through OBS, and I've tried every type of fix I've seen through the forums, but unfortunately no luck. I did notice one thing different compared to everyone else's notes. I have a file called ypushfile3.dll that is causing me problems. I never had any problems with the original Elgato - it was a plug and play, simple use; however, not this.
I have been running it through 32-Bit, and I'm not having problems using the Elgato Software to record videos, but I am having trouble streaming onto Twitch, and previewing it all together. My notes are as follows below:
This crash appears to have occured in the 'c:\program files (x86)\elgato\gamecapture\ypushfile3.dll' module.
Fault address: 0EAAAF28 (c:\program files (x86)\elgato\gamecapture\ypushfile3.dll)
OBS version: Open Broadcaster Software v0.651b
CPU: Intel(R) Core(TM) i7-4770 CPU @ 3.40GHz
Crashing thread stack trace:
0F66F6C8 0EAAAF28 00000067 00000080 00000080 00000080 ypushfile3.dll!0xeaaaf28
0F66F6E4 0EAB3BEE 00000067 00000080 00000080 00000080 ypushfile3.dll!0xeab3bee
0F66F708 0EA4EEF0 0D15D288 606CBFB4 0E09F9D0 0F66F77C ypushfile3.dll!0xea4eef0
0F66F72C 0EA42720 0F66F758 6B170279 606CBFB4 0E09F9D0 ypushfile3.dll!0xea42720
0F66F744 0EA42484 0F66F77C 0E09F9D0 00000014 0F66F7B8 ypushfile3.dll!0xea42484
0F66F774 0EA42BA5 0CE161C8 0EA625E8 0E09F9D0 0EAC290E ypushfile3.dll!0xea42ba5
0F66F788 0EA6DE57 0CE161C8 3A7DA789 606CBFB4 0E0537D8 ypushfile3.dll!0xea6de57
0F66F7C0 606CC01D 606CBFB4 0F66F810 75037C04 0D0CA308 msvcr120.dll!0x606cc01d
0F66F7F8 606CC001 0D0CA308 75037BE0 259C669E 0F66F858 msvcr120.dll!0x606cc001
0F66F804 75037C04 0D0CA308 27A803D8 00000000 00000000 kernel32.dll!0x75037c04
0F66F818 771BAD1F FFFFFFFF 771A0235 00000000 00000000 ntdll.dll!0x771bad1f
0F66F860 771BACEA 606CBFB4 0D0CA308 00000000 00000000 ntdll.dll!0x771bacea
A minidump was saved to C:\Users\Samy\AppData\Roaming\OBS\crashDumps\OBSCrashDump2015-05-18_10.dmp.
List of loaded modules:
Base Address Module
If anyone can help me ever so much, that'd be dandy! Please reply soon! This is a rather frustrating event I'm having.
champdee
I have the same problem as of now... Tried all sorts of uninstalls, reinstalls... etc... what should I do? (elgato hd60)
