Bug Report Elgato Game Capture HD does not work with any other audio input
David Wilding
(XBOX ONE) I'm having an issue with my elgato where I cannot use the Elgato's game capture audio as an input. Any idea's? I linked two images with the settings and while I use the "Elgato Game Capture HD" I get no signal. Meanwhile when set to the default, it works perfectly fine. That's not the way I wan't to stream because then I cannot use my xbox headset to speak to my streaming audience... Please someone help, I'm stuck. I even tried changing the Output audio to desktop instead of stream, nothing is working. I feel like the answer is so simple I'm just overlooking it.
Harold
You won't be able to use your xbox headset for stream voice commentary, etc without a mixer.
Harold
Elgato to "device audio" and the obs mic input to be whatever your mixer is feeding to your computer through (don't hook it up to the elgato)
Harold
Are you using the "With Analog Audio" setting in the elgato settings in the source properties?
David Wilding
Yes, it was working a few days ago, perhaps the update I recently had changed something? Regardless I've still uninstalled everything relevant and reinstalled it. It's not that my elgato doesn't work, it just won't function with the audio I would like in OBS. It works in the software Elgato provides though perfectly fine.
Harold
You shouldn't be unless your mixer is outputting audio to your elgato.
If your mixer is outputting audio to your computer directly, you should use "With analog audio" turned off and OBS set to capture from the mixer as well as the elgato.
