Bug Report Elgato Capture Keeps freezing on OBS on Parallels Desktop
FunFairGamingTV
Hi
I am running Mac and I have a copy of Windows running on Parallels Desktop I am having issues with running my Elgato Capture Card on OBS every time I load the preview stream the picture on OBS just freezes and I have tried restarting over 5 times and I am getting the same issue over again, The other scenes which I have setup with images are working fine with OBS and for also streaming to Twitch but using the Elgato the picture just freezes on the game on OBS I have also set the source the correct way by using global sources to use my Elgato Capture Card but the issue is still occurring.
Here is a Log file…
I hope someone can help!
Thanks
  • LOG .pdf
Lain
Lain
Were you running OBS on parallels? It says you only have one core. If so then running OBS in a VM is a really bad idea.
