Question / Help Drastic FPS drop during League of Legends stream
krismoit
Hey there, here's the log.
https://gist.github.com/02416d253e0ec43a7f4597396ee52768
Trying to stream League Of Legends from a 2.7ghz i7, 8gb ram, MacBook pro 2011.
Not even sure if this thing can power it properly, I've meddled with the settings, but an expert analysis would be much appreciated, even if it's a straight up 'no, you can not power that efficiently on said machine'.
Prior to stream I can get 30-60 fps no problems, as soon as streaming has begun, fps drop to 4-16 fps.
Thanks in advance.
dodgepong
Administrator
Community Helper
Unfortunately that log does not contain a streaming/recording attempt. Can you make a recording, then restart OBS, and upload the "last" log file?
krismoit
I apologize! Okay, so I've gone to fulfill your request & ran into another set of problems. OBS looks different, & crashes when I attempt to do anything. Included is the log & a screenshot of what i'm seeing. I've uninstalled & rebooted, all the general kinda stuff. Not sure what I would've done to cause this, but hopefully we can squash this one, & then move onto the real task at hand, lol. Thanks for your help & patience!
https://gist.github.com/161004533cdafb35b3ddfdf52dce0ff9
krismoit
Please disregard last post, managed to fix it by creating a new template, which caused the app to crash & after re-opening, everything went back to normal.
Going to test stream now.
krismoit
After numerous crashes, I found a work-around by deleting the folder in Application Support also, re-opened & worked like a charm
