Question / Help Dazzle DVC100 and Audio
i3axpace
Hey there - I've done quite a bit of streaming of my PC games, and everything works great, the audio captures fine from both the game and my microphone. However, when it comes to my console games using my Dazzle DVC100, I can capture the video no problem but the audio doesn't seem to want to stream.
Edit: I should clarify, my microphone stays fine, it's just the game audio that doesn't come through.
Thanks for any help in advance!
Lain
Lain
some devices, especially USB devices, currently aren't functioning still. I -am- trying to remedy that, but it will take some time.
kdstudios
I hope this isn't classed as necro'ing as it's less than a month old but this is the latest post I could find relating to this problem.
There was a way to capture audio on Xsplit using the Crossbar and Virtual Audio Cable.
Basically you selected the Dazzle (or easycap or whatever you have) in Xsplit, went to the Cam tab and clicked configure and Crossbar, you then changed Input to Audio Line In and Output to Audio Decoder Out then click Apply/Ok
Will something like this appear in OBS? Because right now this is the only thing holding me back from moving away from Xsplit completely, I use OBS for everything but I have to use Xsplit just to stream older console games with a Dazzle/Easycap.
dehixem
Personnaly I use a USB mic and plug in the audio of the dazzle into the 3.5mm mic port of my PC. Then I listen to the microphone and I got the dazzle sound working perfectly ^^
paibox
heros in an halfshel
There will be some enhancements for the DirectShow plugin coming relatively soon that will let you specify a custom audio source for your capture device and also access the CrossBar, which should allow you to use the native audio input on your Dazzle.
