Bug Report Crashing when starting stream.
S. Jefferspin
I just started to use OBS and got it configured to stream and was working for about 3 hours. Then after an update and restart, it would crash as soon as I tried to preview.
This crash appears to have occured in the 'c:\program files (x86)\obs\64bit\libx264-136.dll' module.
**** UNHANDLED EXCEPTION: c0000094
Fault address: 000007FEEB78AB77 (c:\program files (x86)\obs\64bit\libx264-136.dll)
OBS version: Open Broadcaster Software v0.54b
Crashing thread stack trace:
000000000026BD00 000007FEEB78AB77 00000002000001C0 0000000000000000 0000000000000000 0000000000000000 libx264-136.dll!0x7feeb78ab77
000000000026E810 000007FEEB7FB0B7 0000000000000384 000000000026ED69 0000000000000000 0000000000000001 libx264-136.dll!0x7feeb7fb0b7
000000000026ECD0 000000013F0EB887 0000000000000008 000000000000001E 0000000000000640 467CE52F00000384 obs.exe!X264Encoder::X264Encoder+0x737
000000000026EDB0 000000013F0EC7B8 0000000000001388 000000000026EF20 0000000000610000 0000000000000000 obs.exe!CreateX264Encoder+0xc8
000000000026EE20 000000013F0FC136 0000000080004005 0000000000001395 0000000000070478 00000000000E0642 obs.exe!OBS::Start+0x1446
000000000026F220 000000013F11B27B 0000000000000070 FFFFFFFFFFFFFFFF FFFFFFFFFFFFFFFF 0000000077959B43 obs.exe!OBS::OBSProc+0x189b
000000000026F3A0 0000000077959BD1 0000000000AA3FB0 000000013F1199E0 00000000FFFFFED1 0000000000070478 user32.dll!0x77959bd1
000000000026F460 0000000077956AA8 00000000000E0642 0000000000000111 0000000000001395 000007FEFCD80A29 user32.dll!0x77956aa8
000000000026F4F0 0000000077956BAD 0000000000391400 0000000000000001 0000000000000000 0000000000000001 user32.dll!0x77956bad
000000000026F540 000007FEFCD80BBF 0000000000070478 0000000000000001 0000000000391400 000007FEFDE02421 comctl32.dll!0x7fefcd80bbf
000000000026F580 000007FEFCD847FE 0000000000000000 0000000000000000 0000000000000000 0000000000000000 comctl32.dll!0x7fefcd847fe
000000000026F640 0000000077959BD1 000000000026F900 000007FEFCD83B20 0000000000AA3FB0 0000000000A932C0 user32.dll!0x77959bd1
000000000026F700 00000000779598DA 0000000000000000 0000000000000000 000007FEFCD83B20 0000000000000001 user32.dll!0x779598da
000000000026F780 00000000779567C2 00000000079B0793 00000000079B0793 000007FEFDE0489C 000000000037D700 user32.dll!0x779567c2
000000000026F810 000000013F0F0E49 0000000000000000 0000000000000000 000000013F0D0000 0000000000000000 obs.exe!WinMain+0x8b9
000000000026FD40 000000013F162E00 0000000000000000 0000000000000000 0000000000000000 0000000000000000 obs.exe!strstr+0x1ac
000000000026FDF0 0000000077A5652D 0000000000000000 0000000000000000 0000000000000000 0000000000000000 kernel32.dll!0x77a5652d
000000000026FE20 0000000077B8C521 0000000000000000 0000000000000000 0000000000000000 0000000000000000 ntdll.dll!0x77b8c521
List of loaded modules:
Base Address Module
I can't attach the mini dump at the moment, but will link it as soon as I have it uploaded.
R1CH
No need for the dump, we're looking into this - seems like it was caused by the new update.
dodgepong
Administrator
Community Helper
Have you tried the latest 0.541 update that was pushed last night? I believe it should have fixed this error.
