Crashes when trying to create macro conditions - advanced scene switcher
lvcunq
Hi! I'm new to all these so I am hoping someone out there could help me solve this issue.
When I open advanced scene switcher and create a macro. OBS Studio crashes when I click the "+" button for conditions.
I started using OBS Studio very recently so there's nothing to update whatsoever.
I'm not very sure how to navigate and read through the crash log too, so I have attached it to this thread.
Thank you :(
  • Crash log.pdf
Sorry, no pdf file, only the actual txt file.
pdf may contain malware.
Attach it the same way or use the upload function OBS have inside the Help menu. Yes, OBS have an actual useful Help menu.
This is the cause of the crash:
advanced-scene-switcher
Check to see if there's an update of this plugin compatible with OBS 3.2.* or downgrade OBS.
lvcunq
Oh, I just started OBS Studio very very recently so I never was able to use the plugin.... Sorry...
Then remove the plugin or ask in this plugin discussion page about compatibility and which version is the latest it works as intended.
