Crash with Kernelbase.dll problem
CallMe233
I update to 27.2.3. The crash problem occurs when I try to open the software. I tried some old versions and they still didn't work.
This is the log for 27.2.2(32-bit) and 27.2.0(64-bit).
Any help from anyone is greatly appreciated.
Unhandled exception: e06d7363
Date/Time: 2022-03-10, 19:10:27
Fault address: 761FB922 (c:\windows\system32\kernelbase.dll)
libobs version: 27.2.2 (32-bit)
Windows version: 10.0 build 19044 (release: 2009; revision: 1566; 64-bit)
CPU: Intel(R) Core(TM) i7-8750H CPU @ 2.20GHz
Date/Time: 2022-03-10, 18:56:36
Fault address: 7FFDB8A44F69 (c:\windows\system32\kernelbase.dll)
libobs version: 27.2.0 (64-bit)
  • Crash 2022-03-03 22-20-43.txt
  • Crash 2022-03-10 18-56-36.txt
cyclemat
1. update all drivers from the manufacture homepage
2. Update Bios
3. check you ram with memtest
4. Check you windows files
Start CMD as Admin
type in
dism /Online /Cleanup-Image /ScanHealth
when finished
sfc /scannow
Harold
This specific crash is caused by your intel igpu drivers being out of date.
You need to update your Intel video driver. You have 2 ways you can do this:
  1. Update using the Intel Driver & Support Assistant, available at this link: https://www.intel.com/content/www/us/en/support/detect.html
  2. Update by selecting the appropriate driver for your OS and GPU, at this link: https://downloadcenter.intel.com/product/80939/Graphics-Drivers
Always reboot your PC once your drivers are updated, even if you are not prompted to.
