Bug Report Crash with Error code...
Cryonic
OBS just crashed with the game STALKER: Call of Pripyat Sigerous Mod 2.0 (latest fix installed):
The error code:
Error: Texture->Map failed: 0x887a0005 0x887a0007
Your video card or driver froze and was reset. Please check for possible hardware / driver issues. This error can also occur if you have enabled opencl in x264 custom settings.
Full log attached.
Win7 x64 with AMD r9 270X OC and 14.3 Beta (!) Catalyst driver.
I also have bad performance in LoL with game capture, but this is something different..
Is this because i use the Beta driver or its just a rare crash with a modded game that can happen anytime ?
  • 2014-04-15-0222-31.log
Cryonic
This is the main problem right now - the regular driver dont support Mantle, AMD is still sitting on the 13.12 and i will lose FPS in BF4 & Thief.
The error happened once, i will try to reproduce it while recording. But a solution would be nice for the current beta driver because many people with the R9 cards will use it and its stable.
Sapiens
Test with the non-beta driver to see if the problem still happens. If it doesn't then the issue is most likely with the beta driver and you'll need to wait and see if AMD fixes it with an official release. Beta drivers are beta after all, and bugs/issues are to be expected with them.
Cryonic
I will try to reproduce the error with the beta driver while recording offline to see what games will crash my driver. For now it was just the STALKER CoP with a Sigerous Mod (heavy modded game, it has more problems than just crashing OBS/OpenGL). Other games are working fine.
I`m still waiting for a regular driver with mantle or the next beta driver, but AMD seems to stuck for a while with the current one...
