Bug Report Crash while using FL-Studio
dukeraver
While using the ASIO driver in FL-Studio. Worked fine for a moment, but then crashed my stream. Enjoy!
12:01:16: Open Broadcaster Software v0.638b - 64bit ( ^ω^)
12:01:16: -------------------------------
12:01:16: CPU Name: Intel(R) Core(TM) i7 CPU         920  @ 2.67GHz
12:01:16: CPU Speed: 2664MHz
12:01:16: Physical Memory:  6142MB Total, 3022MB Free
12:01:16: stepping id: 5, model 26, family 6, type 0, extmodel 0, extfamily 0, HTT 1, logical cores 8, total cores 4
12:01:16: monitor 1: pos={0, 0}, size={1920, 1080}
12:01:16: Windows Version: 6.1 Build 7601 S
12:01:16: Aero is Disabled
12:01:16: OBS Modules:
12:01:16: Base Address     Module
12:01:16: 000000003F540000 OBS.exe
12:01:16: 00000000DDB20000 OBSApi.dll
12:01:16: 00000000FAA60000 DShowPlugin.dll
12:01:16: 00000000FA590000 GraphicsCapture.dll
12:01:16: 00000000FA560000 NoiseGate.dll
12:01:16: 00000000F5580000 PSVPlugin.dll
12:01:16: ------------------------------------------
12:01:16: Adapter 1
12:01:16:   Video Adapter: AMD Radeon HD 5700 Series
12:01:16:   Video Adapter Dedicated Video Memory: 1065172992
12:01:16:   Video Adapter Shared System Memory: 2951999488
12:01:16:   Video Adapter Output 1: pos={0, 0}, size={1920, 1080}, attached=true
12:01:16: =====Stream Start: 2015-01-20, 12:01:16===============================================
12:01:16:   Multithreaded optimizations: On
12:01:16:   Base resolution: 1920x1080
12:01:16:   Output resolution: 1280x720
12:01:16: Loading up D3D10 on AMD Radeon HD 5700 Series (Adapter 1)...
12:01:16: Audio Format: 44100 Hz
12:01:16: Audio Channels: 2 Ch
12:01:16: Playback device {0.0.0.00000000}.{c4aeb9ae-e5be-4a30-b26b-0b440fb3266e}
12:01:16: Using desktop audio input: Speakers (3- Corsair Vengeance 1500)
12:01:16: Global Audio time adjust: 0
12:01:17: ------------------------------------------
12:01:17: Using auxilary audio input: Microphone (3- Corsair Vengeance 1500)
12:01:17: Mic time offset: 0
12:01:17: Audio Encoding: MP3
12:01:17:     bitrate: 96
12:01:17: Using bitmap image
12:01:17: Using text output
12:01:17: Scene buffering time set to 700
12:01:17: Video Encoding: x264
12:01:17:     fps: 30
12:01:17:     width: 1280, height: 720
12:01:17:     preset: veryfast
12:01:17:     profile: main
12:01:17:     keyint: 60
12:01:17:     CBR: yes
12:01:17:     CFR: yes
12:01:17:     max bitrate: 400
12:01:17:     buffer size: 300
12:01:19:   Interface: Realtek RTL8168C(P)/8111C(P) Family PCI-E Gigabit Ethernet NIC (NDIS 6.20) (ethernet, 100 mbps)
12:01:19: Completed handshake with rtmp://publish.livestream.com/mogulus/thefurduke/username=thefurduke/password=NOPENOTGETTINGTHIS/isAutoLive=true/aspectWidth=16/aspectHeight=9 in 545 ms.
12:01:21: SO_SNDBUF was at 8192
12:01:21: SO_SNDBUF is now 65536
12:01:57: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
12:01:57:   New Scene
12:01:57: Using Monitor Capture
12:02:17: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
12:02:17:   New Scene
12:02:17: Using bitmap image
12:02:17: Using text output
12:15:41: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
12:15:41:   New Scene
12:15:41: Using Monitor Capture
12:42:04: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
12:42:04:   New Scene
12:42:04: Using bitmap image
12:42:04: Using text output
12:42:05: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
12:42:05:   New Scene
12:42:06: Using bitmap image
12:42:06: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
12:42:06:   New Scene
12:42:06: Using text output
12:52:50: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
12:52:50:   New Scene
12:52:50: Using Monitor Capture
12:55:09: Audio timestamp for device 'Microphone (3- Corsair Vengeance 1500)' was behind target timestamp by 80
12:55:59: Audio device 'Microphone (3- Corsair Vengeance 1500)' has been lost, attempting to reinitialize
12:56:00: Audio device 'Speakers (3- Corsair Vengeance 1500)' has been lost, attempting to reinitialize
12:56:01: Global Audio time adjust: 0
12:56:02: Global Audio time adjust: 0
12:56:03: Global Audio time adjust: 0
12:56:03: Device 'Microphone (3- Corsair Vengeance 1500)' reacquired.
12:56:04: Global Audio time adjust: 0
12:56:04: Device 'Speakers (3- Corsair Vengeance 1500)' reacquired.
12:56:04: RTMPPublisher::SocketLoop: Stalled for 3468 ms to write 362 bytes (buffer: 0 / 131072), unstable connection?
12:56:11: Audio device 'Microphone (3- Corsair Vengeance 1500)' has been lost, attempting to reinitialize
12:56:11: Audio device 'Speakers (3- Corsair Vengeance 1500)' has been lost, attempting to reinitialize
12:56:12: Global Audio time adjust: 0
12:56:13: Global Audio time adjust: 0
12:56:14: Global Audio time adjust: 0
12:56:15: Global Audio time adjust: 0
12:56:16: Global Audio time adjust: 0
12:56:17: Global Audio time adjust: 0
12:56:18: Device 'Microphone (3- Corsair Vengeance 1500)' reacquired.
12:56:18: Global Audio time adjust: 0
12:56:18: Device 'Speakers (3- Corsair Vengeance 1500)' reacquired.
12:56:18: RTMPPublisher::SocketLoop: Stalled for 3033 ms to write 386 bytes (buffer: 0 / 131072), unstable connection?
12:56:42: Audio device 'Microphone (3- Corsair Vengeance 1500)' has been lost, attempting to reinitialize
12:56:42: Audio device 'Speakers (3- Corsair Vengeance 1500)' has been lost, attempting to reinitialize
12:56:43: Global Audio time adjust: 0
12:56:44: Global Audio time adjust: 0
12:56:45: Global Audio time adjust: 0
12:56:46: Global Audio time adjust: 0
12:56:47: Global Audio time adjust: 0
12:56:48: Global Audio time adjust: 0
12:56:49: Global Audio time adjust: 0
12:56:50: Global Audio time adjust: 0
12:56:51: Global Audio time adjust: 0
12:56:52: Global Audio time adjust: 0
12:56:53: Global Audio time adjust: 0
12:56:54: Global Audio time adjust: 0
12:56:55: Global Audio time adjust: 0
12:56:56: Global Audio time adjust: 0
12:56:57: Global Audio time adjust: 0
12:56:58: Global Audio time adjust: 0
12:56:59: Global Audio time adjust: 0
12:57:00: Global Audio time adjust: 0
12:57:01: Global Audio time adjust: 0
12:57:02: Global Audio time adjust: 0
12:57:03: Global Audio time adjust: 0
12:57:04: Global Audio time adjust: 0
12:57:05: Global Audio time adjust: 0
12:57:06: Global Audio time adjust: 0
12:57:07: Global Audio time adjust: 0
12:57:08: Global Audio time adjust: 0
12:57:09: Global Audio time adjust: 0
12:57:10: Global Audio time adjust: 0
12:57:11: Global Audio time adjust: 0
12:57:12: Global Audio time adjust: 0
12:57:13: Global Audio time adjust: 0
12:57:14: Global Audio time adjust: 0
12:57:15: Global Audio time adjust: 0
12:57:16: Global Audio time adjust: 0
12:57:17: Global Audio time adjust: 0
12:57:18: Global Audio time adjust: 0
12:57:19: Global Audio time adjust: 0
12:57:20: Global Audio time adjust: 0
12:57:21: Global Audio time adjust: 0
12:57:22: RTMPPublisher::SocketLoop: Received FD_CLOSE, 32952 ms since last send (buffer: 0 / 131072)
12:57:22: RTMPPublisher::SocketLoop: Aborting due to FD_CLOSE, error 0
12:57:22: Global Audio time adjust: 0
12:57:23: FlushBufferedVideo: Flushing 1219 packets over 40600 ms
12:57:23: Global Audio time adjust: 0
12:57:24: Global Audio time adjust: 0
12:57:25: Global Audio time adjust: 0
12:57:26: Global Audio time adjust: 0
12:57:27: Global Audio time adjust: 0
12:57:28: Global Audio time adjust: 0
12:57:29: Device 'Microphone (3- Corsair Vengeance 1500)' reacquired.
12:57:29: Global Audio time adjust: 0
12:57:29: Device 'Speakers (3- Corsair Vengeance 1500)' reacquired.
12:57:52: WARNING: Forcibly terminating a thread after 30001 ms timeout!
12:58:03: Total frames encoded: 102174, total frames duplicated: 884 (0.87%)
12:58:03: Total frames rendered: 100831, number of late frames: 30 (0.03%) (it's okay for some frames to be late)
  • OBSCrashDump2015-01-20_1.zip
