Bug Report Crash when changeing resolution
Kasper
Crashed using Blackmagic intensity shuttle USB 3.0 i can't get 1280x720 resolution to work at all with this current version of OBS
log file is attached.
  • crashlog 1.pages.zip
Kladdy
The current version is really unstable when it comes to resizing. Either downgrade to 3.1(which is more stable), or wait for the next update(which should fix most crashes).
dodgepong
Administrator
Community Helper
That is an odd looking crash log...did you follow these instructions? https://obsproject.com/forum/thread...re-to-include-a-crash-log-in-your-post.16497/
And Kladdy, I don't know that "most crashes" will be fixed in the next version. We need people testing and reporting crashes with the current version in order to fix those crashes, so we really appreciate people sticking with the current version to help us make it better. If you want most crashes fixed, please stay on 0.4.0 and report crashes when you get them.
Lain
Lain
0.4.0 or 0.4.2? I think we resolved this issue in 0.4.2, which we only just released.
