heya folks i was wondering if anyone could perhaps help me out here, i stream minecraft at 480p, 45fps but want to have no pixelation i have it setup quite well imo but want to know if there is anything i can do to make it better.
my specs are as follows
AMD FX4100
Radeon HD7750
100 meg down 10 meg up
i use 2000 bitrate and CBR enabled so im compliant with the twitch requirements.
now, my question stems from me having to use a 2000 bitrate for 480p to me it seems very high but achieves nice overall quality, is there something that i`m missing?
Also is there a feature that continues to send the stream output after you hit stop stream to avoid the cutting out of any content.
thanks for reading and hope there is some useful info to be had here take it easy all.
AMD FX4100
Radeon HD7750
