So this ONLY happens when I stream CS:GO, everything else works fine. When I try to stream CS:GO it gets this weird effect in game where it appear almost choppy and certain animations glitch out (pulling a chamber on a pistol for example). It's hard on the eyes and makes no sense as I can get a constant 200+ fps WHILE streaming, and am uploading at 3500kb/s... CS:GO is the only game this happens it and it happens if I use xsplit or OBS, however with OBS I get a much higher frame rate so... I was wondering if anyone else has this problem.
PC Specs:
i5-3570 3.40GHz Quadcore Ivybridge
16.0 GB of ram (DDR3 SDRAM DDR3 1600 (PC3 12800))
Radeon HD 7870 Ghz edition
PC Specs:
