Question / Help Could not Create D3D10
djlamar2
Here you go
11:50:17: Open Broadcaster Software v0.542b - 32bit (´・ω・`)
11:50:17: -------------------------------
11:50:17: CPU Name: Intel(R) Celeron(R) CPU 450 @ 2.20GHz
11:50:17: CPU Speed: 2194MHz
11:50:17: Physical Memory: 2012MB Total, 497MB Free
11:50:17: stepping id: 1, model 6, family 6, type 0, extmodel 0, extfamily 0, HTT 0, logical cores 1, total cores 1
11:50:17: monitor 1: pos={0, 0}, size={1366, 768}
11:50:17: Windows Version: 6.1 Build 7601 S
11:50:17: Aero is Enabled
11:50:17: OBS Modules:
11:50:17: Base Address Module
11:50:17: 011E0000 OBS.exe
11:50:17: 5B2C0000 OBSApi.dll
11:50:17: 63620000 DShowPlugin.dll
11:50:17: 6ED60000 GraphicsCapture.dll
11:50:17: 6F880000 NoiseGate.dll
11:50:17: 69FE0000 PSVPlugin.dll
11:50:17: ------------------------------------------
11:50:17: Adapter 1
11:50:17: Video Adapter: Intel(R) G45/G43 Express Chipset
11:50:17: Video Adapter Dedicated Video Memory: 33554432
11:50:17: Video Adapter Shared System Memory: 753393664
11:50:17: =====Stream Start: 2013-08-08, 11:50:17===============================================
11:50:17: Multithreaded optimizations: On
11:50:17: Base resolution: 1280x720
11:50:17: Output resolution: 1280x720
Error: Could not create D3D10 device and swap chain. This error can happen for one of the following reasons:
1.) Your GPU is not supported (DirectX 10 support is required - many integrated laptop GPUs do not support DX10)
2.) You're running Windows Vista without the "Platform Update"
3.) Your video card drivers are out of date
Kharay
Your system simply does not meet the minimal system requirements and even if it did, its performance does not meet any such requirements either.
That CPU alone does not meet the necessary performance on any level, sorry.
dodgepong
Administrator
Community Helper
You can buy a discrete graphics card that supports DirectX 10, but you'll be limited by your CPU, then, too. If you want to stream, you'd be better off getting a new computer.
djlamar2
Already bought a new computer so no I'm not getting 1. Bought it a year ago and other than not being able to use OBS nothing is wrong with it.
djlamar2
Look it may be old but it still works. I can run other programs on it so no I'm not getting a new computer. I have windows 7 for crying out loud.
Krazy
Town drunk
Unfortunately, real time encoding for the purpose of live streaming is a very system intensive task. A lot of older hardware just isn't up to the task. It sucks, but there isn't really a way around it I'm afraid =/
Lain
Lain
Not -yet- at least with OBS, but it may hopefully be fixed eventually (albeit it will probably be painful)
djlamar2
So then its not just me? Well can you at least fix it. Twitch is requiring that I use CBR and other than another program yours is the only 1 that has it.
