Open Broadcaster Software v0.461a - 32bit (´・ω・`)
CPU Name: Intel(R) Core(TM) i3 CPU M 380 @ 2.53GHz
CPU Speed: 2533MHz
Physical Memory: 3894MB Total, 1116MB Free
stepping id: 5, model 5, family 6, type 0, extmodel 1, extfamily 0, HTT 1, logical cores 4, total cores 2
Aero is Enabled
Adapter 1
Video Adapter: Intel(R) HD Graphics
Video Adapter Dedicated Video Memory: 67108864
Video Adapter Shared System Memory: 1711276032
Base resolution: 1366x768
Output resolution: 1364x768
Error: Could not create D3D10 device and swap chain. This error can happen for one of the following reasons:
1.) You're using an old or unsupported GPU (some laptop GPUs can also have this issue)
2.) You're running windows vista without the "Platform Update"
3.) I screwed something up somewhere
