Correct chromakey (some code inside)
anon347
Hi! I want to overlay image on video the use green chromakey. For example, there's two pictures that I want to combine together:
- example of video
and
- example of my overlay
At the moment, I can choose green color in the settings and get something like this:
- 10% similarity
anon347
I can increase level of similarity to 100%, but I steel get some green channel:
I can add blen level to 100, but it don't help to remove all green pixels:
For example, you can see here After Effects filter "key light", I expect to see more
- no green ever!
anon347
GIMP
For example, it GIMP "color to alpha" with green color:
- good, but some purple colors on gradients, compare with:
- it's more expected, but the previous version is acceptable
You may be able to take the algorithm of GIMP and use it in your program?
anon347
My version
My algo, here steel some dirty-yellow colors, but black and white gradients are perfect
My code here. At first, I use ImageMagick to load images:
  int width;
  int height;
  int bytes;
  unsigned char *back;
  unsigned char *mask;
  MagickWandGenesis ();
  MagickWand *wand = NewMagickWand ();
  // load background
  MagickReadImage (wand, "back.png");
  width = MagickGetImageWidth (wand);
  height = MagickGetImageHeight (wand);
  bytes = width * height * 3;
  back = malloc (bytes);
  MagickExportImagePixels (wand, 0, 0, width, height, "RGB", CharPixel, back);
  // load overlay
  MagickWand *wand2 = NewMagickWand ();
  MagickReadImage (wand2, "text.png");
  mask = malloc (bytes);
  MagickExportImagePixels (wand2, 0, 0, width, height, "RGB", CharPixel, mask);
and then process image
The code is not optimal, but it works and gives to understand how the algorithm works
  for (q = 0; q < bytes; q += 3){
      r = mask[q];
      g = mask[q + 1];
      b = mask[q + 2];
      if (g == 255 && r == 0 && b == 0)
          alpha = 0;
          goto redraw;
      if (g <= r || g <= b)
          alpha = 1;
          goto redraw;
      lev = g - r > g - b ? g - b : g - r;
      g -= lev;
      alpha = lev / 255.0;
    redraw:
      if (alpha == 1)
// nothing
      else if (alpha == 0)
          r = back[q];
          g = back[q + 1];
          b = back[q + 2];
      else
          scale = 1 - alpha;
          r = (int) ((double) r + (double) back[q] * alpha);
          g = (int) ((double) g + (double) back[q + 1] * alpha);
          b = (int) ((double) b + (double) back[q + 2] * alpha);
      back[q] = r;
      back[q + 1] = g;
      back[q + 2] = b;
and finally, save image:
  MagickImportImagePixels (wand, 0, 0, width, height, "RGB", CharPixel, back);
  MagickWriteImage (wand, "result.png");
Please, add this chromakey to OBS. Or gimp version.
There are several versions of images, simply attach to the case, if they are interested in
Muf
Image Source uses Color Key, not Chroma Key. It's a different algorithm, made for different purposes. For what you want, just use a PNG file with embedded alpha channel; no keying needed. If you want to see OBS' chroma key algorithm at work, try adding a Video Capture Device and enable the Chroma Key feature there.
anon347
No, I do not want a static image, I want another video on top of it (realtime)
Surprised by the presence of such a function in "Video Capture Device", but its absence in "Monitor Capture/Window Capture". In games capture mode, none at all keying is provided at all.
I want to capture a window/monitor with some realtime graphics, and its contents are to composed over the video.
I don't have any devices for "video capture device", and I think the emulation webcam (screen capture video to virtual webcam) through another program - not the best solution
umer147
dodgepong
Administrator
Community Helper
The standard way to get a feature added to an open source project is to fork the project, add the code, then submit a pull request.
