Should open an explorer window to your application data. There you will find a subfolder called OBS. Just copy that sub-folder to the same %AppData% folder on the 2nd PC, done.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
