Citrix Remote desktop issue
Enrike
Hi,
I have a problem with capture screen and window in OBS. I would like to capture of my virtual desktop, for connection I use Citrix Workspace and Citrix Desktop Viewer (CDViewer.exe) but unfortunatly when I used display capture option then window with virtual my desktop (on top) wasn't visible, just all windows on the screen. Next I tried to use window capture option, I chosen window name but window is black, witout any picture inside it. Is it possible to catch video from Citrix Virtual Desktop on my local machine? I need do it in this way because I have licensed software on virtual machine for which I'm preparing video training. I have connected two monitors to my laptop, is there a problem here?
Thank you for your help, I don't have much experience in this field.
Greetings
koala
There is "Capture Method" in the properties of your window capture. Try all options in the drop down list. May be some non-automatic capture method is able to capture.
About the window missing from display capture: try to use and run the Citrix app on the other display. It's strange, however. Never saw a window missing from being captured by display capture.
Enrike
I tried all options for display and window capture but they change nothing. I do it for my both screens and resoults are the same, I can't see Citrix window on screen, just background, window is not visible on preview and on records (screenshoots attached). I trieid with just one display but it not helped.
Is it possible that Citrix not allow for record of content of virtual desktops?
