Capturing PS3 Stereoscopy
Seamndel
Capture PS3 Stereoscopy
My OBS source displays Frame-Packed stereoscopy in a horizontal 2D split:
https://imgur.com/gallery/y6dOtgl
Can stereoscopy be reconstructed in post after being captured in split 2D feeds? Would it be essential to have both 2D captures in order to make an accurate reconstruction?
If stereoscopy reconstruction can't exist, then what output resolution should I set OBS to? Currently the output resolution is 1280x720. Would it be better to only capture either portion of the screen and have it stretch onto a 1280x720 canvas, or should the resolution be change to a lower one. Are there differences between each portion of the image?
Setup:
Windows 11 PC
Playstation 3
Sony Playstation 3D Display
Elgato HD60 S+ capture card
OREI 4K HDMI Splitter
OBS (capture software)
