Bug Report Capture 3 audio sources
Perfk
I don't know if this is a bug, or a feature request. but here goes.
I wan't to record 3 audio streams:
1: my microphone. (own voice)
2. My speakers (gamesound)
3. My headphone speakers, (Teamspeak voices)
But all i can get is my microphone and either my headphones, or the speakers, i can't get all 3.
Any idears on how to set OBS up so this works?
Tak0r
Depends on how your Teamspeak is Confogured. Set Teamspeak to output to default Audio Device and let obs capture the default audio device
Jack0r
The Helping Squad
You can maybe use Paibox´s DirectShowAudio Plugin to add the third source. But you might have to use one VAC Line1 to do so.
viewtopic.php?f=11&t=2579
The plugin can add several recording devices to your stream. (Set them Up to play on stream only)
Now since you want 2 playback devices and can select your one microphone in obs already, you will need Virtual Audio Cable.
Replace either your Headset or Speakers Audio device with VAC Line1.
For example set Line1 as your default communication device and make sure teamspeak plays on this line. In the Recording Tab, open the options of Line1, go to the Listen tab and set it to Listen to your Headset device. (You can also use a VAC repeater for this step, but you will have to start this repeater everytime you want sound on your headset)
Now back in OBS select your Speakers and Microphone in the OBS settings, and in the Plugin settings you select VAC Line1. (VAC Lines can take in and output and will send it further) Now you should have all 3 sounds on stream.
