"Canvas not found" error when using SE.Live Vertical
ElKesin
I just did a clean install of my OBS to later install the new SE.Live plugin from StreamElements which is used to stream on multiple platforms (multi-streams). It turns out that it has a section to create different canvases but when trying to create a vertical canvas I get the following error (image). I've been looking for an issue on reddit and elsewhere but couldn't find a solution... If anyone knows how to solve it, it would be a great help.
MusicalWhiskey
This seems to be common. I tried switching from Aitum vert only to have the canvas dock not work. The canvas is out of frame of the window and I'm unable to create my scene. I sent SE Live a support ticket. I'll let you know if I hear back.
beccasplaying
Hi, this is an old thread but I am having the same issue and live support were no help. Just wondering if anyone had a solution that works?
