can you finally FIX the audio capture issues ????
Mango-kun
It's so annoying. Since I upgraded to version 31, I can only talk about luck that the audio will be CAPTURED at some time. In version 30. it ALWAYS worked. WHAT HAVE YOU BROKEN THERE ???? Can you guys finally fix it and implement this normally???
I mean: If I upgrade to a NEWER and apparently BETTER version, then it really can't be that in the end everything just gets worse and nothing works.
If this function is “BETA”, what the hell does it do in the release version??? Let it stay in BETA IF IT DOESN'T WORK correctly. I DONT choosen the beta-OBS or something. With every new update there is ALWAYS some NEW shit that I need fix by myself, or switch to NEW plug-ins so that everything works as it did like on the previous version.
PS: I'll say this in advance: You can put such clever sayings like “then don't use it” or similar somewhere else, okay? I use it, precisely BECAUSE the release program offers it, and if it doesn't work properly because it says (BETA) in brackets, that doesn't bother me. Then just cut it out if it's beta — very simple and clumsy logic.
prgmitchell
I have the same issue is or can anybody help. Shall I roll back to the previous version??
Hi, there aren't any new issues with application audio capture and this feature has been mostly untouched since it's original release years ago apart from a few bug fixes. It is still listed with a BETA tag because of an issue from Microsoft that can result in some static audio every so often, this is outside the control of OBS and can be heard in other software that captures audio the same way like Discord. If you are having an issue please make your own thread with details + a log file.
